주요 콘텐츠로 건너뛰기
Insignia NS-CLIP02 Power Auxiliary Port Replacement Replacement
필요한 것
  1. Insignia NS-CLIP02 Power Auxiliary Port Replacement Replacement, Power Auxiliary Port Replacement: 1 단계, 이미지 1/1
    • Locate the bottom of the device.
  2. Insignia NS-CLIP02 Power Auxiliary Port Replacement Replacement: 2 단계, 이미지 1/1
    • Peel back the adhesive sticker using a metal spudger and remove the 11mm screw beneath the sticker with a Phillips head screw driver.
  3. Insignia NS-CLIP02 Power Auxiliary Port Replacement Replacement: 3 단계, 이미지 1/1
    • Using a plastic spudger, peel off the adhesive gel stoppers.
  4. Insignia NS-CLIP02 Power Auxiliary Port Replacement Replacement: 4 단계, 이미지 1/1
    • Unscrew the six 11mm screws with a Phillips head screw driver.
  5. Insignia NS-CLIP02 Power Auxiliary Port Replacement Replacement: 5 단계, 이미지 1/1
    • Remove the bottom of the device to reveal the motherboard.
  6. Insignia NS-CLIP02 Power Auxiliary Port Replacement Replacement: 6 단계, 이미지 1/1
    • Unscrew the 9.5mm screw located near the center of the motherboard with a Phillips head screw driver.
  7. Insignia NS-CLIP02 Power Auxiliary Port Replacement Replacement: 7 단계, 이미지 1/1
    • Lift the motherboard from the device and lie it face down. Beware of the cables plugged in on the back side
  8. Insignia NS-CLIP02 Power Auxiliary Port Replacement Replacement: 8 단계, 이미지 1/1
    • Remove the plug to your left.
  9. Insignia NS-CLIP02 Power Auxiliary Port Replacement Replacement: 9 단계, 이미지 1/1
    • Remove the plug to your right from the motherboard.
  10. Insignia NS-CLIP02 Power Auxiliary Port Replacement Replacement: 10 단계, 이미지 1/1
    • Remove the plug in the front of the lcd screen plug.
  11. Insignia NS-CLIP02 Power Auxiliary Port Replacement Replacement: 11 단계, 이미지 1/1
    • Remove the LCD screen plug last. For reassembly, follow the instructions in reverse order, replacing the old motherboard with the new one to fix the power auxiliary port.
결론
Erik
회원 가입일: 02/19/15
405 평판
안내서 4개 작성하였습니다
USF Tampa, Team 9-3, Leahy Winter 2015 USF Tampa, Team 9-3, Leahy Winter 2015 회원
USFT-LEAHY-W15S9G3
4 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 5
30일 전: 7
전체 시간: 209
