주요 콘텐츠로 건너뛰기
Insignia NS-CLIP02 Speaker replacement and troubleshooting
필요한 것
  1. Insignia NS-CLIP02 Speaker replacement and troubleshooting, Motherboard: 1 단계, 이미지 1/1
    • Set the clock radio on the work space so the bottom of the device is showing.
  2. Insignia NS-CLIP02 Speaker replacement and troubleshooting: 2 단계, 이미지 1/2 Insignia NS-CLIP02 Speaker replacement and troubleshooting: 2 단계, 이미지 2/2
    • Use a metal spudger to peel back the adhesive sticker on the bottom of the clock.
    • You should see a single screw beneath the sticker.
  3. Insignia NS-CLIP02 Speaker replacement and troubleshooting: 3 단계, 이미지 1/2 Insignia NS-CLIP02 Speaker replacement and troubleshooting: 3 단계, 이미지 2/2
    • Using a plastic opening tool, peel off the adhesive gel stoppers.
  4. Insignia NS-CLIP02 Speaker replacement and troubleshooting: 4 단계, 이미지 1/1
    • Use a Phillips screwdriver to remove the six 11 mm screws on the bottom of the device.
  5. Insignia NS-CLIP02 Speaker replacement and troubleshooting: 5 단계, 이미지 1/1
    • Remove the bottom cover from the device to reveal the motherboard.
  6. Insignia NS-CLIP02 Speaker replacement and troubleshooting: 6 단계, 이미지 1/1
    • Use a Phillips screwdriver to remove the 9.5 mm screw located near the center of the motherboard.
  7. Insignia NS-CLIP02 Speaker replacement and troubleshooting: 7 단계, 이미지 1/1
    • Lift the motherboard away from the device.
  8. Insignia NS-CLIP02 Speaker replacement and troubleshooting: 8 단계, 이미지 1/3 Insignia NS-CLIP02 Speaker replacement and troubleshooting: 8 단계, 이미지 2/3 Insignia NS-CLIP02 Speaker replacement and troubleshooting: 8 단계, 이미지 3/3
    • Disconnect the four cables connecting the motherboard to the device.
  9. Insignia NS-CLIP02 Speaker replacement and troubleshooting, Speaker: 9 단계, 이미지 1/1
    • Remove the three screws located along the center of the base.
  10. Insignia NS-CLIP02 Speaker replacement and troubleshooting: 10 단계, 이미지 1/2 Insignia NS-CLIP02 Speaker replacement and troubleshooting: 10 단계, 이미지 2/2
    • Remove the base from the display.
  11. Insignia NS-CLIP02 Speaker replacement and troubleshooting: 11 단계, 이미지 1/3 Insignia NS-CLIP02 Speaker replacement and troubleshooting: 11 단계, 이미지 2/3 Insignia NS-CLIP02 Speaker replacement and troubleshooting: 11 단계, 이미지 3/3
    • Using a metal spudger, remove the plastic face plate from the display.
  12. Insignia NS-CLIP02 Speaker replacement and troubleshooting: 12 단계, 이미지 1/1
    • With a phillips screwdriver, remove the six screws shown pictured to the left.
  13. Insignia NS-CLIP02 Speaker replacement and troubleshooting: 13 단계, 이미지 1/2 Insignia NS-CLIP02 Speaker replacement and troubleshooting: 13 단계, 이미지 2/2
    • Using the metal spudger, pry the speaker grilles from the display.
  14. Insignia NS-CLIP02 Speaker replacement and troubleshooting: 14 단계, 이미지 1/1
    • Using the phillips screwdriver, remove the four screws pictured to the left.
  15. Insignia NS-CLIP02 Speaker replacement and troubleshooting: 15 단계, 이미지 1/1
    • Separate the two pieces of the display as shown.
  16. Insignia NS-CLIP02 Speaker replacement and troubleshooting: 16 단계, 이미지 1/3 Insignia NS-CLIP02 Speaker replacement and troubleshooting: 16 단계, 이미지 2/3 Insignia NS-CLIP02 Speaker replacement and troubleshooting: 16 단계, 이미지 3/3
    • You can see that there are several points where connections to the speaker are soldered.
    • If all connections are soldered then replacement may be necessary.
결론
Aubrey
회원 가입일: 02/24/15
214 평판
안내서 2개 작성하였습니다
USF Tampa, Team 9-3, Leahy Winter 2015 USF Tampa, Team 9-3, Leahy Winter 2015 회원
USFT-LEAHY-W15S9G3
4 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 4
전체 시간: 166
