소개
To replace many parts of the clock radio, the motherboard will need to be removed. This guide will lay out the necessary steps for that process.
필요한 것
Grip the white ribbon cable connector that attaches the lightning cable to the middle of the central circuit board located in the bottom of the clock. Pinch and pull straight up to detach the cable.
Use the narrow end of a plastic spudger to pull back the clip in the center of the board.
At the same time, pry the circuit board up by wedging another spudger into the top left-hand corner of the board and working it along the back, pushing the edge of the board away from the back of the clock.
거의 끝나갑니다!
결승점
