주요 콘텐츠로 건너뛰기
Insignia NS-CLOPP2 Motherboard Replacement
필요한 것
  1. Insignia NS-CLOPP2 Motherboard Replacement, Motherboard: 1 단계, 이미지 1/1
    • First, remove the front screen. (See prerequisite screen removal guide.)
  2. Insignia NS-CLOPP2 Motherboard Replacement: 2 단계, 이미지 1/1
    • Use the plastic opening tool to gently pry the motherboard forward and away from the rest of the device.
  3. Insignia NS-CLOPP2 Motherboard Replacement: 3 단계, 이미지 1/1
    • Gently lift the motherboard up and out, making sure that you don't disassemble any of the wires in place by pulling too hard.
  4. Insignia NS-CLOPP2 Motherboard Replacement: 4 단계, 이미지 1/1
    • To fully remove the motherboard from the clock, use wire cutters to carefully sever the connections between the motherboard and the wires attached.
    • To reassemble your device, follow these instructions in reverse order.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Dilini De Silva
회원 가입일: 03/11/15
757 평판
안내서 5개 작성하였습니다
Marist, Team 1-1, Laflen Spring 2015 Marist, Team 1-1, Laflen Spring 2015 회원
MARS-LAFLEN-S15S1G1
2 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 5
전체 시간: 148
