소개
Is your battery no longer holding a charge? Do you have to keep it plugged in to listen to music? This guide will replace the battery so you can enjoy the speaker for hours in between charges.
필요한 것
Push the Spudger into the crevice between the grated panel of the speaker and the base of the speaker.
Angle the spudger to create a separation between the grate and the base.
다른 4명이 해당 안내서를 완성하였습니다.
댓글 4개
What type of battery does it use?
Did you ever find out what battery it takes?
I found out the correct replacement battery is 18650, 3.7V/2000mAH
