주요 콘텐츠로 건너뛰기
Insignia NS-CSPBTHOL-R Speakers Replacement
필요한 것
  1. Insignia NS-CSPBTHOL-R Speakers Replacement, Speakers: 1 단계, 이미지 1/1
    • Insert the Spudger between the grated panel and the base of the speaker.
  2. Insignia NS-CSPBTHOL-R Speakers Replacement: 2 단계, 이미지 1/1
    • Pull the grated panel off
  3. Insignia NS-CSPBTHOL-R Speakers Replacement: 3 단계, 이미지 1/1
    • Remove the six 3mm screws using the J00 JIS screw bit. This will require a long, narrow screwdriver.
  4. Insignia NS-CSPBTHOL-R Speakers Replacement: 4 단계, 이미지 1/1
    • Insert the Spudger between the corners of base and the face of the speaker to open the device.
    • The screw on the upper right corner may be difficult to take out. If you cannot take it out with a screwdriver, using force to pull the face of the speaker apart may break the plastic that surrounds the screw.
  5. Insignia NS-CSPBTHOL-R Speakers Replacement: 5 단계, 이미지 1/1
    • Remove one speaker at a time
  6. Insignia NS-CSPBTHOL-R Speakers Replacement: 6 단계, 이미지 1/1
    • Grab the back piece of the speaker and gently pull upward.
  7. Insignia NS-CSPBTHOL-R Speakers Replacement: 7 단계, 이미지 1/1
    • Remove speakers gently one at a time.
  8. Insignia NS-CSPBTHOL-R Speakers Replacement: 8 단계, 이미지 1/3 Insignia NS-CSPBTHOL-R Speakers Replacement: 8 단계, 이미지 2/3 Insignia NS-CSPBTHOL-R Speakers Replacement: 8 단계, 이미지 3/3
    이 단계에 사용된 도구:
    구매
    • Using blunted tip tweezers, squeeze and pull on the white plastic clip. This will separate the speaker's wires from the motherboard.
    • The wires are connected to the white plastic clip that is attached to the motherboard.
결론
Lheessis Ruiz
회원 가입일: 02/15/17
101 평판
안내서 1개 작성함
USF Tampa, Team 12-6, Eyestone Spring 2017 USF Tampa, Team 12-6, Eyestone Spring 2017 회원
USFT-EYESTONE-S17S12G6
3 회원들
안내서 4개 작성하였습니다
댓글 한 개
This is a good app really could help some people like myself. Thank you
rrguerrero7330 - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 6
30일 전: 11
전체 시간: 657
