소개
If your speakers no longer sound strong/clear or they stopped producing sound, you may need to replace them. Use this guide to help you replace he speakers.
필요한 것
Insert the Spudger between the corners of base and the face of the speaker to open the device.
The screw on the upper right corner may be difficult to take out. If you cannot take it out with a screwdriver, using force to pull the face of the speaker apart may break the plastic that surrounds the screw.
거의 끝나갑니다!
결론
