소개
If there are major problems with your Insignia NS-D160A14's functionality, it could be due to a faulty motherboard. This short guide will teach you how to remove the motherboard so it can be replaced. The process is very easy, so let's get started!
필요한 것
Unhook the 4 hooks on the main casing.
There is one hook on the top of the casing, one on the bottom, and one on each side.
다른 한 분이 해당 안내서를 완성하였습니다.
