주요 콘텐츠로 건너뛰기
Insignia NS-D160A14 Optical Drive Replacement
필요한 것
  1. Insignia NS-D160A14 Optical Drive Replacement, Outer Case: 1 단계, 이미지 1/1
    • Unplug the power cord before proceeding to open the DVD player's enclosure.
    • Remove the two 7mm Phillips #2 screws from the back of the DVD player.
  2. Insignia NS-D160A14 Optical Drive Replacement: 2 단계, 이미지 1/1
    • Carefully lift the outer case up, starting from the back.
    • Removing the outer case may require some force, and you will need to get the case into an angled position compared to the rest of the DVD player before it can be completely separated.
  3. Insignia NS-D160A14 Optical Drive Replacement, Front Panel: 3 단계, 이미지 1/3 Insignia NS-D160A14 Optical Drive Replacement, Front Panel: 3 단계, 이미지 2/3 Insignia NS-D160A14 Optical Drive Replacement, Front Panel: 3 단계, 이미지 3/3
    • Unhook the 4 hooks on the main casing.
    • There is one hook on the top of the casing, one on the bottom, and one on each side.
    • These hooks are brittle and can easily break.
  4. Insignia NS-D160A14 Optical Drive Replacement, Motherboard: 4 단계, 이미지 1/1
    • Remove the central 7 mm screw holding the motherboard in place.
    • Be sure to ground yourself before manipulating the motherboard. A static shock could render one or more components on the motherboard useless.
  5. Insignia NS-D160A14 Optical Drive Replacement: 5 단계, 이미지 1/1
    • Disconnect the white power cord connector from the motherboard.
  6. Insignia NS-D160A14 Optical Drive Replacement: 6 단계, 이미지 1/2 Insignia NS-D160A14 Optical Drive Replacement: 6 단계, 이미지 2/2
    • Keeping the 8-pin connector as straight as possible, lift the motherboard out of case.
    • You may need to bend the side of the case slightly to give the motherboard room to be lifted out.
  7. Insignia NS-D160A14 Optical Drive Replacement, Optical Drive: 7 단계, 이미지 1/2 Insignia NS-D160A14 Optical Drive Replacement, Optical Drive: 7 단계, 이미지 2/2
    • Disconnect the white cables connected to the optical drive from the A/V board using your fingers.
    • Be careful when removing the cables on the A/V board. Don't put too much pressure on the wires or the wires could be damaged.
  8. Insignia NS-D160A14 Optical Drive Replacement: 8 단계, 이미지 1/1
    • After removing the white wires connected to the A/V board, the optical drive should slide out of the slot.
결론
Ian Hanken
회원 가입일: 07/20/16
516 평판
안내서 5개 작성하였습니다
University of Memphis, Team 1-5, Kim SU 2016 University of Memphis, Team 1-5, Kim SU 2016 회원
UM-KIM-SU16S1G5
4 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 6
전체 시간: 392
