주요 콘텐츠로 건너뛰기
Insignia NS-DS9PDVD15 Disc Reader Replacement
필요한 것
  1. Insignia NS-DS9PDVD15 Disc Reader Replacement, Bottom Cover: 1 단계, 이미지 1/2 Insignia NS-DS9PDVD15 Disc Reader Replacement, Bottom Cover: 1 단계, 이미지 2/2
    • Turn the power off. Slide the power button to OFF.
  2. Insignia NS-DS9PDVD15 Disc Reader Replacement: 2 단계, 이미지 1/2 Insignia NS-DS9PDVD15 Disc Reader Replacement: 2 단계, 이미지 2/2
    • Unplug AC adapter from car cigarette lighter.
  3. Insignia NS-DS9PDVD15 Disc Reader Replacement: 3 단계, 이미지 1/1
    • Make sure there is no DVD or CD in the disc tray
  4. Insignia NS-DS9PDVD15 Disc Reader Replacement: 4 단계, 이미지 1/2 Insignia NS-DS9PDVD15 Disc Reader Replacement: 4 단계, 이미지 2/2
    • Unscrew the nine 9mm screws with a JIS #000 screwdriver.
  5. Insignia NS-DS9PDVD15 Disc Reader Replacement: 5 단계, 이미지 1/3 Insignia NS-DS9PDVD15 Disc Reader Replacement: 5 단계, 이미지 2/3 Insignia NS-DS9PDVD15 Disc Reader Replacement: 5 단계, 이미지 3/3
    • Pry off back panel with prying tool, then remove by hand.
  6. Insignia NS-DS9PDVD15 Disc Reader Replacement, Disc Tray: 6 단계, 이미지 1/2 Insignia NS-DS9PDVD15 Disc Reader Replacement, Disc Tray: 6 단계, 이미지 2/2
    • After the back is removed and the disk tray is loose from the bottom, locate the two, 3 mm screws that hold the tray to the hinge.
    • Unscrew them with the JIS #000 screwdriver.
  7. Insignia NS-DS9PDVD15 Disc Reader Replacement: 7 단계, 이미지 1/1
    • Slide the tray up and off of the hinge completely.
  8. Insignia NS-DS9PDVD15 Disc Reader Replacement, Disc Reader: 8 단계, 이미지 1/1
    • Locate the disk reader, it will be right under the disk chamber.
  9. Insignia NS-DS9PDVD15 Disc Reader Replacement: 9 단계, 이미지 1/1
    • Pick it straight up, it should slide off the three pegs holding it in place, if not, wiggle each peg individually.
  10. Insignia NS-DS9PDVD15 Disc Reader Replacement: 10 단계, 이미지 1/1
    • Once you have it loose, unplug it from the PC Board. Then the disk reader can be removed.
결론
Johnny Rozo
회원 가입일: 04/03/18
583 평판
안내서 4개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 6
전체 시간: 581
