주요 콘텐츠로 건너뛰기
Insignia NS-DS9PDVD15 Disc Tray Replacement
필요한 것
  1. Insignia NS-DS9PDVD15 Disc Tray Replacement, Bottom Cover: 1 단계, 이미지 1/2 Insignia NS-DS9PDVD15 Disc Tray Replacement, Bottom Cover: 1 단계, 이미지 2/2
    • Turn the power off. Slide the power button to OFF.
  2. Insignia NS-DS9PDVD15 Disc Tray Replacement: 2 단계, 이미지 1/2 Insignia NS-DS9PDVD15 Disc Tray Replacement: 2 단계, 이미지 2/2
    • Unplug AC adapter from car cigarette lighter.
  3. Insignia NS-DS9PDVD15 Disc Tray Replacement: 3 단계, 이미지 1/1
    • Make sure there is no DVD or CD in the disc tray
  4. Insignia NS-DS9PDVD15 Disc Tray Replacement: 4 단계, 이미지 1/2 Insignia NS-DS9PDVD15 Disc Tray Replacement: 4 단계, 이미지 2/2
    • Unscrew the nine 9mm screws with a JIS #000 screwdriver.
  5. Insignia NS-DS9PDVD15 Disc Tray Replacement: 5 단계, 이미지 1/3 Insignia NS-DS9PDVD15 Disc Tray Replacement: 5 단계, 이미지 2/3 Insignia NS-DS9PDVD15 Disc Tray Replacement: 5 단계, 이미지 3/3
    • Pry off back panel with prying tool, then remove by hand.
  6. Insignia NS-DS9PDVD15 Disc Tray Replacement, Disc Tray: 6 단계, 이미지 1/2 Insignia NS-DS9PDVD15 Disc Tray Replacement, Disc Tray: 6 단계, 이미지 2/2
    • After the back is removed and the disk tray is loose from the bottom, locate the two, 3 mm screws that hold the tray to the hinge.
    • Unscrew them with the JIS #000 screwdriver.
  7. Insignia NS-DS9PDVD15 Disc Tray Replacement: 7 단계, 이미지 1/1
    • Slide the tray up and off of the hinge completely.
결론
Conner Kaer
회원 가입일: 04/05/18
85 평판
안내서 1개 작성함
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 124
