주요 콘텐츠로 건너뛰기
Insignia NS-DS9PDVD15 Latch Replacement
필요한 것
  1. Insignia NS-DS9PDVD15 Latch Replacement, Bottom Cover: 1 단계, 이미지 1/2 Insignia NS-DS9PDVD15 Latch Replacement, Bottom Cover: 1 단계, 이미지 2/2
    • Turn the power off. Slide the power button to OFF.
  2. Insignia NS-DS9PDVD15 Latch Replacement: 2 단계, 이미지 1/2 Insignia NS-DS9PDVD15 Latch Replacement: 2 단계, 이미지 2/2
    • Unplug AC adapter from car cigarette lighter.
  3. Insignia NS-DS9PDVD15 Latch Replacement: 3 단계, 이미지 1/1
    • Make sure there is no DVD or CD in the disc tray
  4. Insignia NS-DS9PDVD15 Latch Replacement: 4 단계, 이미지 1/2 Insignia NS-DS9PDVD15 Latch Replacement: 4 단계, 이미지 2/2
    • Unscrew the nine 9mm screws with a JIS #000 screwdriver.
  5. Insignia NS-DS9PDVD15 Latch Replacement: 5 단계, 이미지 1/3 Insignia NS-DS9PDVD15 Latch Replacement: 5 단계, 이미지 2/3 Insignia NS-DS9PDVD15 Latch Replacement: 5 단계, 이미지 3/3
    • Pry off back panel with prying tool, then remove by hand.
  6. Insignia NS-DS9PDVD15 Latch Replacement, Latch: 6 단계, 이미지 1/1
    • After the back is removed and you can see the interior of the device, push the old latch out.
  7. Insignia NS-DS9PDVD15 Latch Replacement: 7 단계, 이미지 1/2 Insignia NS-DS9PDVD15 Latch Replacement: 7 단계, 이미지 2/2
    • Push the new latch in where the old latch was previously held
    • You can lightly tap it from the inside to make sure the new latch is sliding left and right.
결론
Trenton
회원 가입일: 04/04/18
85 평판
안내서 1개 작성함
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 3
30일 전: 3
전체 시간: 312
