주요 콘텐츠로 건너뛰기
Insignia NS-F12R6-SS Fan Blade Replacement
필요한 것
  1. Insignia NS-F12R6-SS Fan Blade Replacement, Front Cage: 1 단계, 이미지 1/2 Insignia NS-F12R6-SS Fan Blade Replacement, Front Cage: 1 단계, 이미지 2/2
    • Unplug your fan.
    • Remove the 20 mm bolt that fastens the fan ring located at the bottom of the fan cage with a Phillips #3 screwdriver.
  2. Insignia NS-F12R6-SS Fan Blade Replacement: 2 단계, 이미지 1/1
    • Remove the ring that runs around the edge of the fan cage.
  3. Insignia NS-F12R6-SS Fan Blade Replacement: 3 단계, 이미지 1/1
    • Remove the front of the fan cage.
  4. Insignia NS-F12R6-SS Fan Blade Replacement, Fan Blade: 4 단계, 이미지 1/1
    • Remove the 8 mm bolt fastening the fan blades to the rotor with a Phillip #3 screwdriver.
  5. Insignia NS-F12R6-SS Fan Blade Replacement: 5 단계, 이미지 1/1
    • Take caution when removing the fan blades. They can be sharp!
    • Slide the fan blade off the end of the rotor.
결론
Hank
회원 가입일: 09/17/18
1,064 평판
안내서 8개 작성하였습니다
CSU Fullerton, Team S2-G1, Bruce Fall 2018 CSU Fullerton, Team S2-G1, Bruce Fall 2018 회원
CSUF-BRUCE-F18S2G1
4 회원들
안내서 8개 작성하였습니다
0 댓글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 4
전체 시간: 319
