이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Remove the four 6.0 mm Phillips screws located below the rubber caps using the PH00 bit installed in the driver.
Use the plastic opening tool to pry open the back cover.
Slide the tool around the sides of the radio to gradually pry the back cover off. Do not remove the cover completely as there is still a cable connecting it to radio.
Use the blunt tweezers to unplug the battery cable from the PCB board. Grab the battery cable plug from the sides.
Use the flat side of the Spudger to pry the battery out of the back cover.
Insert the replacement battery into the back cover.
Reassemble the radio, making sure to reconnect the battery cable.
다른 2명이 해당 안내서를 완성하였습니다.
