주요 콘텐츠로 건너뛰기
Insignia NS-HTMC01-B Fan Replacement
필요한 것
  1. Insignia NS-HTMC01-B Fan Replacement, Fan: 1 단계, 이미지 1/1
    • Flip your device over so the back panel faces you. You should see a hole containing a screw in each corner of the device.
    • Insert a 4-inch Phillips #1 screwdriver into each hole until connected with the 20 millimeter, sharp-point screw.
  2. Insignia NS-HTMC01-B Fan Replacement: 2 단계, 이미지 1/1
    • Rotate the screwdriver counter-clockwise until screws are removed.
    • Make sure to firmly connect your screwdriver with the head of the screw. A loose connection can strip the screw head, making the screws impossible to remove.
    • Remove the back panel.
  3. Insignia NS-HTMC01-B Fan Replacement: 3 단계, 이미지 1/1
    • Unscrew the four 9 millimeter, sharp-point screws holding the fan in place.
  4. Insignia NS-HTMC01-B Fan Replacement: 4 단계, 이미지 1/2 Insignia NS-HTMC01-B Fan Replacement: 4 단계, 이미지 2/2
    이 단계에 사용된 도구:
    구매
    • Use tweezers to disconnect the red and black wires.
    • Remove the fan.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Jack Casey
회원 가입일: 01/31/17
231 평판
안내서 2개 작성하였습니다
University of North Texas, Team 1-1, Campbell Spring 2017 University of North Texas, Team 1-1, Campbell Spring 2017 회원
UNT-CAMPBELL-S17S1G1
3 회원들
안내서 12개 작성하였습니다
댓글 한 개
But what is the fan size?
William McGroarty - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 11
전체 시간: 293
