주요 콘텐츠로 건너뛰기
Insignia NS-HTMC01-B Power Button Replacement
필요한 것
  1. Insignia NS-HTMC01-B Power Button Replacement, Power Button: 1 단계, 이미지 1/1
    • Flip your device over so the bottom panel faces you. You should see a hole containing a screw in each corner of the device.
    • Insert a 4-inch Phillips #1 screwdriver into each hole until connected with the 20 millimeter, sharp-point screw.
  2. Insignia NS-HTMC01-B Power Button Replacement: 2 단계, 이미지 1/1
    • Find the power switch, located inside the heater on the bottom left corner.
  3. Insignia NS-HTMC01-B Power Button Replacement: 3 단계, 이미지 1/1
    • Using a Phillips #1 screwdriver, unscrew the two 7 millimeter screws attaching the power switch to the power button.
  4. Insignia NS-HTMC01-B Power Button Replacement: 4 단계, 이미지 1/2 Insignia NS-HTMC01-B Power Button Replacement: 4 단계, 이미지 2/2
    • Find the clips holding the power button in place.
    • Press down on the clips to remove the button.
결론
Jack Casey
회원 가입일: 01/31/17
231 평판
안내서 2개 작성하였습니다
University of North Texas, Team 1-1, Campbell Spring 2017 University of North Texas, Team 1-1, Campbell Spring 2017 회원
UNT-CAMPBELL-S17S1G1
3 회원들
안내서 12개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 5
전체 시간: 130
