주요 콘텐츠로 건너뛰기
Insignia NS-HTMC01-B Power Cord Replacement
필요한 것
  1. Insignia NS-HTMC01-B Power Cord Replacement, Front Case: 1 단계, 이미지 1/3 Insignia NS-HTMC01-B Power Cord Replacement, Front Case: 1 단계, 이미지 2/3 Insignia NS-HTMC01-B Power Cord Replacement, Front Case: 1 단계, 이미지 3/3
    • Flip the device over so the back panel faces up.
    • Unscrew the four screws counter-clockwise from the back panel using a 4mm Phillips screwdriver.
    • You may want to use a flashlight during this step, as the screws are hard to see.
    • Make sure to firmly connect your screwdriver with the head of the screw. A loose connection can strip the screw head, making the screws nearly impossible to remove.
  2. Insignia NS-HTMC01-B Power Cord Replacement: 2 단계, 이미지 1/1
    • Take the screws out and set them aside.
    • Be sure to set them somewhere flat, so they don't roll away.
    • Gently pull the front panel and back panel apart to open the device.
  3. Insignia NS-HTMC01-B Power Cord Replacement, Power Cord: 3 단계, 이미지 1/1
    • Use a Phillips #2 screwdriver to remove the two 1.7mm screws from the white triangular piece covering the power cord.
  4. Insignia NS-HTMC01-B Power Cord Replacement: 4 단계, 이미지 1/1
    • Disconnect all of the blue wires. There should be 3 separate blue-wire connections.
  5. Insignia NS-HTMC01-B Power Cord Replacement: 5 단계, 이미지 1/1
    • Disconnect the second black wire from the rectangular piece above the Tip-Over Safety Switch.
    • Remove power cord.
결론
Rebecca Nunez
회원 가입일: 01/31/17
201 평판
안내서 2개 작성하였습니다
University of North Texas, Team 1-1, Campbell Spring 2017 University of North Texas, Team 1-1, Campbell Spring 2017 회원
UNT-CAMPBELL-S17S1G1
3 회원들
안내서 12개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 8
전체 시간: 191
