소개
Replace the power indicator light of your Insignia NS-HTMC01-B heater.
필요한 것
Flip the device over so the back panel faces up.
Unscrew the four screws counter-clockwise from the back panel using a 4mm Phillips screwdriver.
Locate the bottom left corner below the fan inside of the heater.
There is a small black rectangular box with two cables coming out of it.
Using a Phillips #4 screwdriver, unscrew the two screws at the base counterclockwise, and set the screws to the side.
After unscrewing the black rectangular box up from the base of the grey frame, locate the small green rectangular light fixture.
Unscrew the one screw from the green rectangle counter clockwise, and set the screw to the side.
Gently lift the green circuit board out of the socket by pulling on the black and white cables.
