소개
Make sure the device is powered off before you start following the instructions. If you have a physical disability with your hand, wrist, or arm consider having a different individual help you because the tasks require steady hands. Be sure to work on a flat surface and to not lose any of the small parts because they are very small and can be lost easily.
필요한 것
Once the battery and back cover have been successfully removed, use the soldering iron. Place the soldering iron on the solders until properly heated.
거의 끝나갑니다!
결론
