주요 콘텐츠로 건너뛰기
Insignia NS-VCS14SL7 Power Button Replacement
필요한 것
  1. Insignia NS-VCS14SL7 Power Button Replacement, Battery: 1 단계, 이미지 2개 중 1개 Insignia NS-VCS14SL7 Power Button Replacement, Battery: 1 단계, 이미지 2개 중 2개
    • Push down the black button to release the dust cup.
    • Pull the dust cup up and away from handheld portion to remove.
  2. Insignia NS-VCS14SL7 Power Button Replacement: 2 단계, 이미지 3개 중 1개 Insignia NS-VCS14SL7 Power Button Replacement: 2 단계, 이미지 3개 중 2개 Insignia NS-VCS14SL7 Power Button Replacement: 2 단계, 이미지 3개 중 3개
    • Remove the five 12.0 mm screws on the back of the handheld portion using the Phillips #2 screwdriver.
    • Lift the silver cover off of the black body of the handheld portion to expose the battery and wiring.
  3. Insignia NS-VCS14SL7 Power Button Replacement: 3 단계, 이미지 2개 중 1개 Insignia NS-VCS14SL7 Power Button Replacement: 3 단계, 이미지 2개 중 2개
    • Pull apart the red and black wires.
    • Do so for all of the wires. (Red x1, Black x2)
  4. Insignia NS-VCS14SL7 Power Button Replacement: 4 단계, 이미지 1개 중 1개
    • Remove the tape holding the battery to the black housing.
    • Slide the entire battery bundle out.
  5. Insignia NS-VCS14SL7 Power Button Replacement, Handheld Vacuum Power Button: 5 단계, 이미지 1개 중 1개
    • Remove motor and impeller housing to gain access to power button.
  6. Insignia NS-VCS14SL7 Power Button Replacement: 6 단계, 이미지 2개 중 1개 Insignia NS-VCS14SL7 Power Button Replacement: 6 단계, 이미지 2개 중 2개
    • Pry upwards on the retaining clip with black plastic spudger and pull to remove the 5 pin connector.
  7. Insignia NS-VCS14SL7 Power Button Replacement: 7 단계, 이미지 2개 중 1개 Insignia NS-VCS14SL7 Power Button Replacement: 7 단계, 이미지 2개 중 2개
    • Remove the two 10mm Philips #2 screws holding the brown printed circuit board to the vacuum.
    • Remove brown printed circuit board.
    • Pull up on clear plastic power button assembly to remove.
결론
작성자
3다른 기여자 명과 함께
Thibaut Pillot
회원 가입일: 02/15/18
434 평판
안내서 5개를 작성함
USF Tampa, Team S16-G3, Boczar Spring 2018 USF Tampa, Team S16-G3, Boczar Spring 2018 회원
USFT-BOCZAR-S18S16G3
4 회원들
안내서 12개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 10
전체 시간: 333
