주요 콘텐츠로 건너뛰기
Insignia Sport NS-4V17 Battery Replacement
필요한 것
  1. Insignia Sport NS-4V17 Battery Replacement, Battery: 1 단계, 이미지 1/1
    • Remove the 3mm Phillips #00 screw on the back of the Insignia NS-4v17.
  2. Insignia Sport NS-4V17 Battery Replacement: 2 단계, 이미지 1/2 Insignia Sport NS-4V17 Battery Replacement: 2 단계, 이미지 2/2
    • Detach the back cover by carefully pulling up and out on the back plastic casing.
    • Do not pull apart the red wire connecting the battery to the device.
  3. Insignia Sport NS-4V17 Battery Replacement: 3 단계, 이미지 1/1
    • Use the plastic opening tool to reach underneath the battery, opposite from the side with the red wire, and remove it from its plastic case.
    • Be careful to not tear the wires while opening the case.
  4. Insignia Sport NS-4V17 Battery Replacement: 4 단계, 이미지 1/1
    • Reach under the white plastic wire connector using the plastic opening tool and disconnect it from the socket.
    • Do not disconnect wires from plastic connector.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
David Poltorak
회원 가입일: 04/18/13
4 평판
안내서 1개 작성함
Cal Poly, Team 12-36, Amido Spring 2013 Cal Poly, Team 12-36, Amido Spring 2013 회원
CPSU-AMIDO-S13S12G36
4 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 13
전체 시간: 1,097
