주요 콘텐츠로 건너뛰기
Insignia Sport NS-4V17 Front Case Cover Replacement
필요한 것
  1. Insignia Sport NS-4V17 Front Case Cover Replacement, Battery: 1 단계, 이미지 1/1
    • Remove the 3mm Phillips #00 screw on the back of the Insignia NS-4v17.
  2. Insignia Sport NS-4V17 Front Case Cover Replacement: 2 단계, 이미지 1/2 Insignia Sport NS-4V17 Front Case Cover Replacement: 2 단계, 이미지 2/2
    • Detach the back cover by carefully pulling up and out on the back plastic casing.
    • Do not pull apart the red wire connecting the battery to the device.
  3. Insignia Sport NS-4V17 Front Case Cover Replacement: 3 단계, 이미지 1/1
    • Use the plastic opening tool to reach underneath the battery, opposite from the side with the red wire, and remove it from its plastic case.
    • Be careful to not tear the wires while opening the case.
  4. Insignia Sport NS-4V17 Front Case Cover Replacement: 4 단계, 이미지 1/1
    • Reach under the white plastic wire connector using the plastic opening tool and disconnect it from the socket.
    • Do not disconnect wires from plastic connector.
  5. Insignia Sport NS-4V17 Front Case Cover Replacement, Front Case Cover: 5 단계, 이미지 1/2 Insignia Sport NS-4V17 Front Case Cover Replacement, Front Case Cover: 5 단계, 이미지 2/2
    • Remove the four corner plastic covers on the back of the device using the plastic opening tool.
  6. Insignia Sport NS-4V17 Front Case Cover Replacement: 6 단계, 이미지 1/1
    • Using a Philips #00 screwdriver remove all four 4.5mm corner screws located underneath the corner pads.
  7. Insignia Sport NS-4V17 Front Case Cover Replacement: 7 단계, 이미지 1/3 Insignia Sport NS-4V17 Front Case Cover Replacement: 7 단계, 이미지 2/3 Insignia Sport NS-4V17 Front Case Cover Replacement: 7 단계, 이미지 3/3
    • Carefully wedge the plastic opening tool into either long side of the device.
    • Slowly move the plastic opening tool along the side of the device, separating the front and back case covers.
    • Repeat these steps on the other side of the device.
  8. Insignia Sport NS-4V17 Front Case Cover Replacement: 8 단계, 이미지 1/1
    • Once the front cover is loose, use your fingers to remove the front case cover for a new installation.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Wesley Ballar
회원 가입일: 04/18/13
88 평판
안내서 4개 작성하였습니다
Cal Poly, Team 12-36, Amido Spring 2013 Cal Poly, Team 12-36, Amido Spring 2013 회원
CPSU-AMIDO-S13S12G36
4 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 9
전체 시간: 356
