주요 콘텐츠로 건너뛰기
Inspiron 7359 2-in-1 Battery Replacement
필요한 것
  1. Inspiron 7359 2-in-1 Battery Replacement, Bottom Case: 1 단계, 이미지 1개 중 1개
    • Turn off device before starting.
    • Turn the laptop upside down with the logo facing the surface of the table.
  2. Inspiron 7359 2-in-1 Battery Replacement: 2 단계, 이미지 2개 중 1개 Inspiron 7359 2-in-1 Battery Replacement: 2 단계, 이미지 2개 중 2개
    • Use a Phillips #0 screwdriver to remove the ten 8mm screws from the back case of the laptop.
  3. Inspiron 7359 2-in-1 Battery Replacement: 3 단계, 이미지 1개 중 1개
    • Use a spudger to separate the back cover from the laptop.
    • Start from one corner and work your way around the edge of the cover.
    • Be careful not to bend or crack the back cover.
  4. Inspiron 7359 2-in-1 Battery Replacement: 4 단계, 이미지 1개 중 1개
    • All hardware components should be exposed.
  5. Inspiron 7359 2-in-1 Battery Replacement, Battery: 5 단계, 이미지 1개 중 1개
    • Unscrew two 8mm screws with a Phillips #0 screwdriver.
    • Unscrew one silver, wide-head, 8mm screw with a Phillips #0 screwdriver.
    • Disconnect the battery cable from the motherboard.
    • Make sure to keep all screws together and label where you unscrewed them from.
  6. Inspiron 7359 2-in-1 Battery Replacement: 6 단계, 이미지 1개 중 1개
    • To remove the old battery, lift from the bottom and pull the battery towards you.
결론
To reassemble your device, follow these instructions in reverse order using a new battery.
다른 2명이 해당 안내서를 완성하였습니다.
작성자
7다른 기여자 명과 함께
Alfredo Acosta
회원 가입일: 08/26/19
141 평판
안내서 1개를 작성함
Gateway, Team S1-G3, Saknee Fall 2019 Gateway, Team S1-G3, Saknee Fall 2019 회원
GCC-SAKNEE-F19S1G3
4 회원들
안내서 6개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 38
지난 30일: 50
전체 시간: 183
