주요 콘텐츠로 건너뛰기
Inspiron 7359 2-in-1 Fan Replacement
필요한 것
  1. Inspiron 7359 2-in-1 Fan Replacement, Bottom Case: 1 단계, 이미지 1개 중 1개
    • Turn off device before starting.
    • Turn the laptop upside down with the logo facing the surface of the table.
  2. Inspiron 7359 2-in-1 Fan Replacement: 2 단계, 이미지 2개 중 1개 Inspiron 7359 2-in-1 Fan Replacement: 2 단계, 이미지 2개 중 2개
    • Use a Phillips #0 screwdriver to remove the ten 8mm screws from the back case of the laptop.
  3. Inspiron 7359 2-in-1 Fan Replacement: 3 단계, 이미지 1개 중 1개
    • Use a spudger to separate the back cover from the laptop.
    • Start from one corner and work your way around the edge of the cover.
    • Be careful not to bend or crack the back cover.
  4. Inspiron 7359 2-in-1 Fan Replacement: 4 단계, 이미지 1개 중 1개
    • All hardware components should be exposed.
  5. Inspiron 7359 2-in-1 Fan Replacement, Hard Disk Drive: 5 단계, 이미지 1개 중 1개
    • Unscrew three 3mm screws with a Phillips #0 screwdriver and remove them.
    • These screws hold the hdd and removing these screws will make it easier to remove it.
  6. Inspiron 7359 2-in-1 Fan Replacement: 6 단계, 이미지 2개 중 1개 Inspiron 7359 2-in-1 Fan Replacement: 6 단계, 이미지 2개 중 2개
    • Lift the hard drive from the left side. Be careful not pull on it.
    • Pull the SATA cable that's connect to the hard drive and then carefully place the cable on the side.
  7. Inspiron 7359 2-in-1 Fan Replacement, Fan: 7 단계, 이미지 2개 중 1개 Inspiron 7359 2-in-1 Fan Replacement, Fan: 7 단계, 이미지 2개 중 2개
    • Carefully pull the fan adapter labelled one.
  8. Inspiron 7359 2-in-1 Fan Replacement: 8 단계, 이미지 1개 중 1개
    • Pull the wire from the hook to make it easier to take the whole fan out.
  9. Inspiron 7359 2-in-1 Fan Replacement: 9 단계, 이미지 1개 중 1개
    • Remove one 5mm screw using the Phillips screw.
    • After the screw is extracted use your hands and carefully take the fan out.
결론
작성자
4다른 기여자 명과 함께
Dominique
회원 가입일: 08/26/19
251 평판
안내서 2개를 작성함
Gateway, Team S1-G3, Saknee Fall 2019 Gateway, Team S1-G3, Saknee Fall 2019 회원
GCC-SAKNEE-F19S1G3
4 회원들
안내서 6개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 20
지난 30일: 22
전체 시간: 497
