주요 콘텐츠로 건너뛰기
Inspiron 7359 2-in-1 Screen Replacement
필요한 것
  1. Inspiron 7359 2-in-1 Screen Replacement, Bottom Case: 1 단계, 이미지 1개 중 1개
    • Turn off device before starting.
    • Turn the laptop upside down with the logo facing the surface of the table.
  2. Inspiron 7359 2-in-1 Screen Replacement: 2 단계, 이미지 2개 중 1개 Inspiron 7359 2-in-1 Screen Replacement: 2 단계, 이미지 2개 중 2개
    • Use a Phillips #0 screwdriver to remove the ten 8mm screws from the back case of the laptop.
  3. Inspiron 7359 2-in-1 Screen Replacement: 3 단계, 이미지 1개 중 1개
    • Use a spudger to separate the back cover from the laptop.
    • Start from one corner and work your way around the edge of the cover.
    • Be careful not to bend or crack the back cover.
  4. Inspiron 7359 2-in-1 Screen Replacement: 4 단계, 이미지 1개 중 1개
    • All hardware components should be exposed.
  5. Inspiron 7359 2-in-1 Screen Replacement, Screen: 5 단계, 이미지 1개 중 1개
    • Using a spudger or opening pick, carefully pry in between the screen and the screen backing.
    • After opening the LCD Screen, slowly and carefully open the laptop so the front of the screen touches the keyboard.
  6. Inspiron 7359 2-in-1 Screen Replacement: 6 단계, 이미지 1개 중 1개
    • Slowly peel back the tape that is attached to the screen itself.
    • Once the tape is removed, gently disconnect the attached cables.
  7. Inspiron 7359 2-in-1 Screen Replacement: 7 단계, 이미지 1개 중 1개
    • Carefully disconnect the attached cable.
    • Once you remove the attached cable, gently lift up the LCD panel.
결론
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
다른 2명이 해당 안내서를 완성하였습니다.
작성자
7다른 기여자 명과 함께
Dominique
회원 가입일: 08/26/19
251 평판
안내서 2개를 작성함
Gateway, Team S1-G3, Saknee Fall 2019 Gateway, Team S1-G3, Saknee Fall 2019 회원
GCC-SAKNEE-F19S1G3
4 회원들
안내서 8개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 8
전체 시간: 577
