소개
Kyocera only provides drivers for Mac OS 9 and Mac OS 10.4 for the FS-1010. In this Guide a workaround is used to to install drivers for this printer on current versions of macOS.
This Guide was tested on macOS 10.14 Mojave and macOS 11 Big Sur.
Even though this guide is written for the FS-1010, you may be able to install drivers for other Kyocera printers or even printers from other manufacturers as well using this guide. You may need to adapt the steps to your conditions and circumstances.
Click on the Category "Support & Download" at the top of the site
On the opening web page, scroll down until you get to the Download-Center.
Choose "Drucken" under Produkt Funktion and "FS-1010" under Produkt.
Click on >Go afterwards.
Scroll all the way down until you get to the drivers for Linux and Mac.
Download the Linux-Drivers (Linux PPDs) by clicking the fitting link.
Connect the printer via USB with your Mac or use a LAN-Cable to connect the printer to your local network.
Turn on the printer by flicking the switch on the back side. Wait until only the first Status LED is light up.
Click on the Apple-Logo in the top left corner and then open "System Preferences".
Click on the Icon for "Printers & Scanners", after the system preferences we're opened.
Afterswards click in the opening window on the small + in the down left corner.
Choose your printer in the list to configure it.
Give the printer a name and a location (optional).
Open the menu next to the line "Use" and choose "Other file...".
Navigate to the Downloads-folder and then into the folder you just downloaded (PPD's_KSL_8.4).
Navigate to the sub-directory "English" and choose the file "Kyocera_Mita_FS-1010_en.ppd".
Afterwards click on the button "Open" in the down right corner.
Open a new Finder window and click on "Go to" -> "Open Folder..." in the menu bar.
In the appearing window, type in the directory /Library/Printers/PPDs/Contents/Resources and click on "Open".
Navigate to your Downloads folder and the folder we downloaded earlier (PPD's_KSL_8.4). Open the sub-directory "English" and copy the file "Kyocera_Mita_FS-1010_en.ppd" to /Library/Printers/PPDs/Contents/Resources.
As described in step 4-6, open System Preferences and the menu "Printers".
Under "Use" select the option "Choose Software".
In the appearing list, choose the software for the FS-1010 and click "OK".
Now the name of the driver should show up under "Use". Now you can click on "Add".
The printer now gets configured.
In the now opening window you need to select the options that are available in your printer. If your done, press "OK" in den down right corner.
Choose the printer we just added in the list on the left side and click on "Options & Ink Level...".
Click on "Options" and set up the options according to those that are available in your printer. If you are done, click "OK".
After the installation is completed, the printer and the correct driver should show up in the list.
To print a test page, click on "Open printer wait list...".
Afterwards, click on Printer -> print test page.
If the test page gets printed without any problems, the installation was successful. The printer now gets used with the fitting Kyocera driver.
다른 3명이 해당 안내서를 완성하였습니다.
다음 번역가들에게 특별히 감사 드립니다:
100%
Beerwema님은 저희가 세상을 수리하는데 동참하신 분입니다! 기여하시겠습니까?
번역 시작하기 ›
댓글 21개
Überragend!!! Vielen Dank! Ich habe diesen Workaround unter MacOS Catalina in Verbindung mit einem Kyocera FS-1800+ durchgeführt und der Drucker läuft perfekt!!! DANKE DANKE DANKE
Es freut mich, dass Sie den Drucker nun weiterverwenden können und Ihnen meine Anleitung geholfen hat. Viel Spaß beim Drucken! :-)
Beerwema -
Super, habe eben nach langem rumprobieren meinen Kyocera fs1370 als Netzwerkdrucker mit den Linux Treibern unter Big Sur einrichten können (PPD musste in der Bibliothek eingefügt werden). Dachte schon ich muss in einen neuen Drucker investieren. DANKE!
Es freut mich, dass Ihnen meine Anleitung geholfen hat und Sie den Drucker nun weiter verwenden können.
Ich habe ebenfalls vor Kurzem Big Sur installiert und stand vor dem gleichen Problem wie Sie - den Menüpunkt “Andere” gab es bei mir nicht mehr. Nach einigem rumprobieren und recherchieren bin ich darauf gekommen, dass der Treiber in die Bibliothek kopiert werden muss. Daraufhin habe ich die Anleitung aktualisiert.
Viel Spaß beim Drucken :-)
Beerwema -
Passt! FS-1041 auf BigSur. Danke!
Timo Kraft - 답글
