주요 콘텐츠로 건너뛰기
Install Ubuntu 16 on the Pixel
  1. Install Ubuntu 16 on the Pixel, Enable stuff!: 1 단계, 이미지 2개 중 1개 Install Ubuntu 16 on the Pixel, Enable stuff!: 1 단계, 이미지 2개 중 2개
    • Enable Developer Mode/Legacy Boot
    • As mentioned before, you don't need to flash your BIOS, we'll just use the stock SeaBIOS.
    • This means you'll have to press "crtl" + "L" on each boot
    • It'll take some time so grab a coffee while you're waiting...
  2. Install Ubuntu 16 on the Pixel, Boot up Ubuntu: 2 단계, 이미지 1개 중 1개
    • Unlike the Windows installation, you don't need a USB keyboard or mouse to boot the OS
    • Select your USB installer drive on startup
    • You should get the Ubuntu startup screen
  3. Install Ubuntu 16 on the Pixel: 3 단계, 이미지 2개 중 1개 Install Ubuntu 16 on the Pixel: 3 단계, 이미지 2개 중 2개
    • I highly recommend you connect to Wi-Fi before you continue to get all the necessary drivers
    • The Wi-Fi card is automatically detected on boot
    • Just step through the installer like you would with any other distro
  4. Install Ubuntu 16 on the Pixel, Reboot: 4 단계, 이미지 1개 중 1개
    • Remove your installation media and reboot when prompted by Ubuntu
    • On startup, login to your account and setup your hotkeys to enable volume (mute, decrease, increase).
    • Display brightness can be fixed by setting up a custom keymapping:
    • sudo apt-get install xdotool
    • name: Brightness Up command: xdotool key XF86MonBrightnessUp
    • name: Brightness Down command: xdotool key XF86MonBrightnessDown
결론
You're done! If you ever want to get back to ChromeOS just create a recovery drive in your Chrome browser and enable secure boot at the Pixel startup.
작성자
2다른 기여자 명과 함께
Kevin Fessler
회원 가입일: 04/16/16
1,830 평판
안내서 4개를 작성함
2가이드 댓글
Trying to do the brightness key map .I did this sudo apt-get install xdotool.What do I do next i cant seem to find the app xdotool ?
wesley tejeda - 답글
Does it support the light bar in any way or is there a way to enable it
Naru Fox - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 14
전체 시간: 3,756
