주요 콘텐츠로 건너뛰기
Install an Extension Cord Female Plug
필요한 것
  1. Install an Extension Cord Female Plug, Install an Extension Cord Female Plug: 1 단계, 이미지 3개 중 1개 Install an Extension Cord Female Plug, Install an Extension Cord Female Plug: 1 단계, 이미지 3개 중 2개 Install an Extension Cord Female Plug, Install an Extension Cord Female Plug: 1 단계, 이미지 3개 중 3개
    • Install an Extension Cord Female Plug is a relatively simple process that anyone can do at home. This is the cord that we will repair.
    • Disconnect the cable before carrying out any repair work.
    • Use a utility knife to cleanly cut from the middle and around the cable.
  2. Install an Extension Cord Female Plug: 2 단계, 이미지 3개 중 1개 Install an Extension Cord Female Plug: 2 단계, 이미지 3개 중 2개 Install an Extension Cord Female Plug: 2 단계, 이미지 3개 중 3개
    • Use wire strippers to remove about 2 cm from the inner wires
  3. Install an Extension Cord Female Plug: 3 단계, 이미지 2개 중 1개 Install an Extension Cord Female Plug: 3 단계, 이미지 2개 중 2개
    • Make sure you put the bottom cover of the female plug.
  4. Install an Extension Cord Female Plug: 4 단계, 이미지 3개 중 1개 Install an Extension Cord Female Plug: 4 단계, 이미지 3개 중 2개 Install an Extension Cord Female Plug: 4 단계, 이미지 3개 중 3개
    • The green screw is for the (green wire), the gold screw is for the (black wire), and the silver screw is for the (white wire).
    • For green wire.
    • For black wire
    • For white wire.
    • Now when you have each wire inside the hole you tighten the three screws.
  5. Install an Extension Cord Female Plug: 5 단계, 이미지 3개 중 1개 Install an Extension Cord Female Plug: 5 단계, 이미지 3개 중 2개 Install an Extension Cord Female Plug: 5 단계, 이미지 3개 중 3개
    • Electrical tape is optional.
    • Need to make sure both of the parts are lined up in the same directions.
    • Push both parts together and you would see the screws pop up.
  6. Install an Extension Cord Female Plug: 6 단계, 이미지 3개 중 1개 Install an Extension Cord Female Plug: 6 단계, 이미지 3개 중 2개 Install an Extension Cord Female Plug: 6 단계, 이미지 3개 중 3개
    • Tightening the top three screws.
    • Also, need to tighten the two bottom screws.
    • Make sure you have one or two fingers in the back of the two screws so they pop up.
  7. Install an Extension Cord Female Plug: 7 단계, 이미지 1개 중 1개
    • Test out.
결론
다른 2명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Steven Quintero
회원 가입일: 10/23/23
172 평판
안내서 1개를 작성함
CSU Los Angeles, Team 5-20, Kershman Fall 2023 CSU Los Angeles, Team 5-20, Kershman Fall 2023 회원
CSULA-KERSHMAN-F23S5G20
1 회원
안내서 2개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 25
지난 30일: 102
전체 시간: 1,357
