소개
Some people don't like having a front license plate, but driving without a front license plate is a violation that could result in a ticket. Fortunately, you can relocate your license plate using the tow hole license plate mounting adapter without any modification or drilling into your front bumper.
필요한 것
If you compare the stock tow hook and the stick from the license plate mount, you will notice that the threading is a little different.
This is actually because the stock tow hook is made with steel from a mold and the license plate mounting stick is made with CNC machinery.
CNC machinery = computerized machine used to carve aluminum
Remove tow hole cover
Every car is different! Some cars require a pry tool. Others you can simply use your finger to push the corner.
Insert license plate mount stick
Make sure stick is inserted in so it's perpendicular to the opening
Tip! There is only one point where the threading can latch on. Keep turning the license plate mount stick clockwise until it latches. Do not tilt the stick in any way
The tow hole adapter stick does not have to be extremely tight, just adequately secured would be fine. You can use a wrench if you feel like you cannot get enough grip with your fingers.
Mount license plate. Use one of the 1/4" nuts that's included in the package. Insert the screw to mount them together.
This increases the friction between the license plate mount stick and the plate to prevent spinning.
The adapter license plate is designed with curves so you can tilt it to make sure it's parallel with the car bumper.
The bolts are specially designed to use the hex tool included in the package so that the license plate adapter is difficult to steal once it's installed. Use the hex tool and wrench to secure.
Not only does installing this front bumper license plate mounting bracket look great, but you also don't have to worry about getting a ticket!
다른 3명이 해당 안내서를 완성하였습니다.
