주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Install iJDMTOY Front Bumper Tow Hook License Plate Adapter
필요한 것
    1. Install iJDMTOY Front Bumper Tow Hook License Plate Adapter, Before we get started: 1 단계, 이미지 1개 중 1개
      • If you compare the stock tow hook and the stick from the license plate mount, you will notice that the threading is a little different.
      • This is actually because the stock tow hook is made with steel from a mold and the license plate mounting stick is made with CNC machinery.
      • CNC machinery = computerized machine used to carve aluminum
      댓글 쓰기
    2. Install iJDMTOY Front Bumper Tow Hook License Plate Adapter, Removing tow hole cover: 2 단계, 이미지 1개 중 1개
      • Remove tow hole cover
      • Every car is different! Some cars require a pry tool. Others you can simply use your finger to push the corner.
      댓글 쓰기
    3. Install iJDMTOY Front Bumper Tow Hook License Plate Adapter, Insert stick: 3 단계, 이미지 1개 중 1개
      • Insert license plate mount stick
      • Make sure stick is inserted in so it's perpendicular to the opening
      • Tip! There is only one point where the threading can latch on. Keep turning the license plate mount stick clockwise until it latches. Do not tilt the stick in any way
      • The tow hole adapter stick does not have to be extremely tight, just adequately secured would be fine. You can use a wrench if you feel like you cannot get enough grip with your fingers.
      댓글 쓰기
    4. Install iJDMTOY Front Bumper Tow Hook License Plate Adapter, Mount license plate: 4 단계, 이미지 2개 중 1개 Install iJDMTOY Front Bumper Tow Hook License Plate Adapter, Mount license plate: 4 단계, 이미지 2개 중 2개
      • Mount license plate. Use one of the 1/4" nuts that's included in the package. Insert the screw to mount them together.
      • This increases the friction between the license plate mount stick and the plate to prevent spinning.
      • The adapter license plate is designed with curves so you can tilt it to make sure it's parallel with the car bumper.
      • The bolts are specially designed to use the hex tool included in the package so that the license plate adapter is difficult to steal once it's installed. Use the hex tool and wrench to secure.
      댓글 쓰기
    5. Install iJDMTOY Front Bumper Tow Hook License Plate Adapter: 5 단계, 이미지 2개 중 1개 Install iJDMTOY Front Bumper Tow Hook License Plate Adapter: 5 단계, 이미지 2개 중 2개
      • If you feel that the license plate is not secure enough, you can use an extra nut and screw included in the package.
      • Most people only secure their license plate from the top, so you will definitely have more than enough nuts and screws.
      댓글 쓰기
결론
Not only does installing this front bumper license plate mounting bracket look great, but you also don't have to worry about getting a ticket!
취소: 해당 안내서를 완성하지 않았습니다.
다른 3명이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Eric Wu
회원 가입일: 01/21/15
3,600 평판
안내서 23개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 21
지난 30일: 103
전체 시간: 9,100
