소개
Retirez l'écran LCD pour accéder aux pièces internes de votre iMac.
필요한 것
Collez une ventouse sur chacun des deux angles supérieurs de la vitre.
Si la ventouse n'adhère pas à la vitre, essayez de les nettoyer, l'une et l'autre, à l'aide d'un solvant doux.
Retirez les deux vis Torx T10 8 mm par lesquelles l'écran est fixé au boîtier extérieur.
Pour remonter votre appareil, suivez les mêmes instructions dans l'ordre inverse.
다른 36명이 해당 안내서를 완성하였습니다.
다음 번역가들에게 특별히 감사 드립니다:
100%
이 번역자 분들은 저희가 세상을 수리하는데 동참해 주시는 분입니다! 기여하시겠습니까?
번역 시작하기 ›
댓글 3개
i have a problem with my pc.
when i turn on my computer couple i had lot of times the LCD turned off.
is the time to change it? The boot and the system runs ok... what's the problem?
need help guys!
good morning everyone. I have a problem with my iMac. unfortunately the screen starts to look with horizontal stripes. after verifying that it is not by the graphics card, I bought a led a different model and some connectors are different. He led riding my iMac is lm215wf3 (sl) (a1) and I bought by mistake lm215wf3 (sd) (a1). several problems. the temperature sensor input is different, and led backlightsync also is different.
Thanks for posting this guide. I had a bad display connection that caused my Mac display to go off (black) every now and then. Remote desktop showed Mac was fully functional, though. Removed the glass, removed the LCD as per this guide, cleaned all display connectors with WD40, mounted everything back and… voilà !
Martins Jr - 답글
