주요 콘텐츠로 건너뛰기
Installing a Zipper in a Patagonia Fleece Jacket
필요한 것
동영상 개요
Patagonia fleece repair overview.
  1. Installing a Zipper in a Patagonia Fleece Jacket, Zipper: 1 단계, 이미지 1/2 Installing a Zipper in a Patagonia Fleece Jacket, Zipper: 1 단계, 이미지 2/2
    • Lay your jacket face-up onto a flat surface like a table. Unzip the zipper as much as possible.
    • Fold open the bottom corner of the jacket.
  2. Installing a Zipper in a Patagonia Fleece Jacket: 2 단계, 이미지 1/3 Installing a Zipper in a Patagonia Fleece Jacket: 2 단계, 이미지 2/3 Installing a Zipper in a Patagonia Fleece Jacket: 2 단계, 이미지 3/3
    • Rip the seam that holds the zipper in place. This is the outside seam of the two rows of stitching.
    • Start ripping the inside seam.
    • Rip only a few of the stitches.
    • Be sure to avoid ripping the serged edge. To do this, start the blade pointing away from the serge seam.
  3. Installing a Zipper in a Patagonia Fleece Jacket: 4 단계, 이미지 1/3 Installing a Zipper in a Patagonia Fleece Jacket: 4 단계, 이미지 2/3 Installing a Zipper in a Patagonia Fleece Jacket: 4 단계, 이미지 3/3
    • After you have ripped a few stitches, fold the jacket closed again.
    • Pull the zipper webbing away from the teeth of the zipper.
    • Rip the stitches holding the webbing to the zipper.
  4. Installing a Zipper in a Patagonia Fleece Jacket: 5 단계, 이미지 1/3 Installing a Zipper in a Patagonia Fleece Jacket: 5 단계, 이미지 2/3 Installing a Zipper in a Patagonia Fleece Jacket: 5 단계, 이미지 3/3
    • At the top of the zipper there will be an area where the collar is folded back over itself. Rip out the outermost seam holding the zipper webbing in place.
    • Both the zipper webbing and zipper should now be free from the jacket.
    • Repeat steps 1-5 on the other side of the zipper. The second side may or may not have webbing.
  5. Installing a Zipper in a Patagonia Fleece Jacket: 6 단계, 이미지 1/2 Installing a Zipper in a Patagonia Fleece Jacket: 6 단계, 이미지 2/2
    • Lay your jacket out, holding it to full length but not stretched. Measure from the top of the collar to waist.
    • Measure the same length on your zipper from the zipper stop up. Mark this with tailor’s chalk.
    • Measure two inches above that line and make a second mark with your tailor’s chalk.
    • Cut the zipper at the first mark you made. Be sure to cut between the teeth of the zipper to preserve your scissors.
    • Be sure that the zipper slider is below your first mark so you don't cut it off!
    • Use end nipper pliers to cut off all of the zipper teeth above the first mark.
    • Cut the teeth in half, and then remove the back half with your fingers.
    • Remove two teeth below the mark on one side.
    • Repeat this step on the other side of the zipper, removing three teeth below the mark instead of two.
  6. Installing a Zipper in a Patagonia Fleece Jacket: 8 단계, 이미지 1/3 Installing a Zipper in a Patagonia Fleece Jacket: 8 단계, 이미지 2/3 Installing a Zipper in a Patagonia Fleece Jacket: 8 단계, 이미지 3/3
    • Place the zipper stop directly above the last tooth on the zipper. Be sure you get all the way around the zipper.
    • Crimp the zipper stop into place using pliers.
    • Repeat this step on the second side of the zipper.
  7. Installing a Zipper in a Patagonia Fleece Jacket: 9 단계, 이미지 1/3 Installing a Zipper in a Patagonia Fleece Jacket: 9 단계, 이미지 2/3 Installing a Zipper in a Patagonia Fleece Jacket: 9 단계, 이미지 3/3
    • Take the side of the zipper that had webbing, and fold the excess zipper tape on the end of the zipper away from the zipper teeth at a slight angle.
  8. Installing a Zipper in a Patagonia Fleece Jacket: 10 단계, 이미지 1/3 Installing a Zipper in a Patagonia Fleece Jacket: 10 단계, 이미지 2/3 Installing a Zipper in a Patagonia Fleece Jacket: 10 단계, 이미지 3/3
    • Place the folded zipper end into the sewing machine.
    • Tack the fold into place with a few stitches.
  9. Installing a Zipper in a Patagonia Fleece Jacket: 11 단계, 이미지 1/2 Installing a Zipper in a Patagonia Fleece Jacket: 11 단계, 이미지 2/2
    • Clip the threads on the zipper.
    • Repeat steps 9-11 on the other side of the zipper.
  10. Installing a Zipper in a Patagonia Fleece Jacket: 12 단계, 이미지 1/3 Installing a Zipper in a Patagonia Fleece Jacket: 12 단계, 이미지 2/3 Installing a Zipper in a Patagonia Fleece Jacket: 12 단계, 이미지 3/3
    • Take the side of the zipper that had the webbing, and lay it back into the webbing, aligning the zipper tape edge along the serged edge of the webbing.
    • Place the top of the zipper in the crease of the fold of the webbing at the collar.
    • Fold the top of the zipper webbing over the zipper at the crease of the collar.
  11. Installing a Zipper in a Patagonia Fleece Jacket: 14 단계, 이미지 1/2 Installing a Zipper in a Patagonia Fleece Jacket: 14 단계, 이미지 2/2
    • Pin the folded zipper webbing in place.
  12. Installing a Zipper in a Patagonia Fleece Jacket: 15 단계, 이미지 1/2 Installing a Zipper in a Patagonia Fleece Jacket: 15 단계, 이미지 2/2
    • Pin the length of the zipper to the webbing, making sure that the zipper tape edge is still aligned with the serged edge of the webbing.
    • The serged edge is the edge with the, overlock, or zigzag stitching.
  13. Installing a Zipper in a Patagonia Fleece Jacket: 16 단계, 이미지 1/2 Installing a Zipper in a Patagonia Fleece Jacket: 16 단계, 이미지 2/2
    • Position the webbing and zipper in the sewing machine 1/4 of an inch from the zipper teeth on the side of the zipper tape.
    • Sew the zipper onto the webbing.
  14. Installing a Zipper in a Patagonia Fleece Jacket: 17 단계, 이미지 1/3 Installing a Zipper in a Patagonia Fleece Jacket: 17 단계, 이미지 2/3 Installing a Zipper in a Patagonia Fleece Jacket: 17 단계, 이미지 3/3
    • While you’re sewing, remove the pins as you come to them. Running them over with your machine may break your needle.
  15. Installing a Zipper in a Patagonia Fleece Jacket: 18 단계, 이미지 1/2 Installing a Zipper in a Patagonia Fleece Jacket: 18 단계, 이미지 2/2
    • Backstitch at the end of the zipper to prevent the seam from unraveling.
    • Cut the threads, and free the zipper and webbing from the sewing machine.
  16. Installing a Zipper in a Patagonia Fleece Jacket: 19 단계, 이미지 1/2 Installing a Zipper in a Patagonia Fleece Jacket: 19 단계, 이미지 2/2
    • Take the jacket collar and open the folded section that you ripped out in step 6.
    • Sandwich the top of the zipper and webbing in between the two layers as you would see it when it is finished.
    • Align the top of the webbing with the border between the fleece and the start of the same type of fabric as the webbing, about 1/4 inch below the edge of the collar.
  17. Installing a Zipper in a Patagonia Fleece Jacket: 20 단계, 이미지 1/3 Installing a Zipper in a Patagonia Fleece Jacket: 20 단계, 이미지 2/3 Installing a Zipper in a Patagonia Fleece Jacket: 20 단계, 이미지 3/3
    • Fold the backside of the collar fabric over the webbing that covers the zipper seam.
    • Holding the backside of the collar fabric in place, turn the collar back to the front side.
  18. Installing a Zipper in a Patagonia Fleece Jacket: 21 단계, 이미지 1/2 Installing a Zipper in a Patagonia Fleece Jacket: 21 단계, 이미지 2/2
    • Still holding the zipper and webbing between the two layers of collar fabric, pin the layers in place.
    • Continue pinning the webbing and zipper to the inside of the jacket, along the seam you originally ripped.
  19. Installing a Zipper in a Patagonia Fleece Jacket: 22 단계, 이미지 1/2 Installing a Zipper in a Patagonia Fleece Jacket: 22 단계, 이미지 2/2
    • When you come to the jacket's waist, sandwich the webbing and zipper between the folded edge at the waist.
  20. Installing a Zipper in a Patagonia Fleece Jacket: 23 단계, 이미지 1/2 Installing a Zipper in a Patagonia Fleece Jacket: 23 단계, 이미지 2/2
    • Change the presser foot to the zipper foot.
    • Sew the edge of the fleece to the jacket as close to the edge as possible.
    • Be sure to backstitch at each end of the seam.
  21. Installing a Zipper in a Patagonia Fleece Jacket: 24 단계, 이미지 1/2 Installing a Zipper in a Patagonia Fleece Jacket: 24 단계, 이미지 2/2
    • Topstitch the fleece to the zipper 1/4 inch from the zipper.
    • Backstitch at both ends of the seam.
  22. Installing a Zipper in a Patagonia Fleece Jacket: 25 단계, 이미지 1/2 Installing a Zipper in a Patagonia Fleece Jacket: 25 단계, 이미지 2/2
    • Sandwich the second side of the zipper in the collar just as you did the first side. This side will not have webbing.
    • Align the zipper at the waist of the jacket, sandwiching the zipper into the waist as necessary.
  23. Installing a Zipper in a Patagonia Fleece Jacket: 26 단계, 이미지 1/1
    • Align the second side of the zipper at the border of the fleece (or any other fabric like a wind resistant material) about a quarter of an inch below the top edge of the collar, as you did on the previous side.
  24. Installing a Zipper in a Patagonia Fleece Jacket: 27 단계, 이미지 1/2 Installing a Zipper in a Patagonia Fleece Jacket: 27 단계, 이미지 2/2
    • Check that the zipper is sandwiched in the collar as on the other side.
    • Pin the second side of the zipper in place.
  25. Installing a Zipper in a Patagonia Fleece Jacket: 28 단계, 이미지 1/3 Installing a Zipper in a Patagonia Fleece Jacket: 28 단계, 이미지 2/3 Installing a Zipper in a Patagonia Fleece Jacket: 28 단계, 이미지 3/3
    • Replace the zipper foot in your machine.
    • As before, sew the zipper into place very close to the edge.
  26. Installing a Zipper in a Patagonia Fleece Jacket: 29 단계, 이미지 1/2 Installing a Zipper in a Patagonia Fleece Jacket: 29 단계, 이미지 2/2
    • Topstitch the second side as before.
    • Clip threads, check out your work, and give yourself a pat on the back.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Brittany McCrigler
회원 가입일: 03/05/12
88,232 평판
안내서 132개 작성하였습니다
iFixit iFixit 회원
Community
141 회원들
안내서 17,743개 작성하였습니다
0 댓글
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 30
30일 전: 129
전체 시간: 23,434
