주요 콘텐츠로 건너뛰기
Instant Pot 60 EPC Circuit Board Replacement
필요한 것
  1. Instant Pot 60 EPC Circuit Board Replacement, Circuit Board: 1 단계, 이미지 3개 중 1개 Instant Pot 60 EPC Circuit Board Replacement, Circuit Board: 1 단계, 이미지 3개 중 2개 Instant Pot 60 EPC Circuit Board Replacement, Circuit Board: 1 단계, 이미지 3개 중 3개
    • Ensure the device is unplugged and cool before beginning.
    • Remove the lid and inner pot from the Instant Pot and turn the body upside down.
    • Remove the single Torx screw.
  2. Instant Pot 60 EPC Circuit Board Replacement: 2 단계, 이미지 2개 중 1개 Instant Pot 60 EPC Circuit Board Replacement: 2 단계, 이미지 2개 중 2개
    • Turn the bottom face counterclockwise and remove it.
  3. Instant Pot 60 EPC Circuit Board Replacement: 3 단계, 이미지 3개 중 1개 Instant Pot 60 EPC Circuit Board Replacement: 3 단계, 이미지 3개 중 2개 Instant Pot 60 EPC Circuit Board Replacement: 3 단계, 이미지 3개 중 3개
    • In order to reach the circuit board you'll need to remove the secondary frame surrounding it.
    • Remove the three Phillips screws securing the frame.
    • Lift the frame, twist and set next to the body. Take care not to damage any of the attached wiring.
  4. Instant Pot 60 EPC Circuit Board Replacement: 4 단계, 이미지 3개 중 1개 Instant Pot 60 EPC Circuit Board Replacement: 4 단계, 이미지 3개 중 2개 Instant Pot 60 EPC Circuit Board Replacement: 4 단계, 이미지 3개 중 3개
    • Depress the latch securing the red connector and disconnect it.
    • Repeat the previous bullet for the white and black connectors.
    • It can be helpful to gently rock them back and forth while pulling up.
  5. Instant Pot 60 EPC Circuit Board Replacement: 5 단계, 이미지 2개 중 1개 Instant Pot 60 EPC Circuit Board Replacement: 5 단계, 이미지 2개 중 2개
    • Use a Phillips screwdriver to remove the two screws holding each of the two leads in place.
  6. Instant Pot 60 EPC Circuit Board Replacement: 6 단계, 이미지 2개 중 1개 Instant Pot 60 EPC Circuit Board Replacement: 6 단계, 이미지 2개 중 2개
    • Gently walk the 8x1 pin connector out of its socket.
    • It may be helpful to also rock the plug side to side while pulling up.
  7. Instant Pot 60 EPC Circuit Board Replacement: 7 단계, 이미지 3개 중 1개 Instant Pot 60 EPC Circuit Board Replacement: 7 단계, 이미지 3개 중 2개 Instant Pot 60 EPC Circuit Board Replacement: 7 단계, 이미지 3개 중 3개
    • Slide the blue sheathing up to expose the small hole in the lead.
    • Place a SIM card punch into the hole to unsecure the leads and pull them up. If a SIM card punch is not available, then a paperclip or earring should suffice.
    • Repeat for the other two leads.
  8. Instant Pot 60 EPC Circuit Board Replacement: 8 단계, 이미지 2개 중 1개 Instant Pot 60 EPC Circuit Board Replacement: 8 단계, 이미지 2개 중 2개
    • Pull the board up slightly to unclip it from its stand and lift from the body to remove the circuit board.
  9. Instant Pot 60 EPC Circuit Board Replacement: 9 단계, 이미지 1개 중 1개
    • Instant Pot does not provide a new sensor with the device, so it will have to be purchased from a secondary source.
결론
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
다른 4명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Bela Hernandez
회원 가입일: 08/28/24
998 평판
안내서 5개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 19
지난 30일: 85
전체 시간: 707
