주요 콘텐츠로 건너뛰기
Instant Pot 60 EPC Pressure Sensor Replacement
필요한 것
  1. Instant Pot 60 EPC Pressure Sensor Replacement, Pressure Sensor: 1 단계, 이미지 3개 중 1개 Instant Pot 60 EPC Pressure Sensor Replacement, Pressure Sensor: 1 단계, 이미지 3개 중 2개 Instant Pot 60 EPC Pressure Sensor Replacement, Pressure Sensor: 1 단계, 이미지 3개 중 3개
    • Ensure the device is unplugged and cool before beginning.
    • Remove the lid and inner pot from the Instant Pot and turn the body upside down.
    • Remove the single Torx screw.
  2. Instant Pot 60 EPC Pressure Sensor Replacement: 2 단계, 이미지 2개 중 1개 Instant Pot 60 EPC Pressure Sensor Replacement: 2 단계, 이미지 2개 중 2개
    • Turn the bottom face counterclockwise and remove it.
  3. Instant Pot 60 EPC Pressure Sensor Replacement: 3 단계, 이미지 3개 중 1개 Instant Pot 60 EPC Pressure Sensor Replacement: 3 단계, 이미지 3개 중 2개 Instant Pot 60 EPC Pressure Sensor Replacement: 3 단계, 이미지 3개 중 3개
    • In order to reach the pressure sensor you'll need to remove the secondary frame.
    • Remove the three Phillips screws securing the frame.
    • Lift the frame, twist and set next to the body. Take care not to damage any of the attached wiring.
    • Locate the sensor. It has been highlighted in the final image.
  4. Instant Pot 60 EPC Pressure Sensor Replacement: 4 단계, 이미지 2개 중 1개 Instant Pot 60 EPC Pressure Sensor Replacement: 4 단계, 이미지 2개 중 2개
    • To remove the sensor, unscrew the main screw between the sensor and slide out.
  5. Instant Pot 60 EPC Pressure Sensor Replacement: 5 단계, 이미지 3개 중 1개 Instant Pot 60 EPC Pressure Sensor Replacement: 5 단계, 이미지 3개 중 2개 Instant Pot 60 EPC Pressure Sensor Replacement: 5 단계, 이미지 3개 중 3개
    • To remove the leads connecting the sensor to the motherboard you will need to unclip them.
    • In order to do so, slide the blue covering up to expose the small hole in the lead.
    • Place a SIM card punch into the hole to unsecure the leads and pull them up. If a SIM card punch is not avaliable then a paperclip or earring should suffice.
  6. Instant Pot 60 EPC Pressure Sensor Replacement: 6 단계, 이미지 2개 중 1개 Instant Pot 60 EPC Pressure Sensor Replacement: 6 단계, 이미지 2개 중 2개
    • There will be a secondary lead that is black connecting the sensor the the motherboard.
    • In order to remove that lead just squeeze and pull up.
  7. Instant Pot 60 EPC Pressure Sensor Replacement: 7 단계, 이미지 1개 중 1개
    • Instant Pot does not provide a new sensor with the device, so it will have to be purchased from a secondary source.
결론
다른 4명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Bela Hernandez
회원 가입일: 08/28/24
998 평판
안내서 5개를 작성함
1가이드 댓글
My pro plus comes with only one sensor. Where can I find it's replacement?
Dr. Khalid S - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 10
지난 30일: 64
전체 시간: 539
