메인 콘텐츠로 스킵하기
소개
The LED display is how you communicate with your Instant Pot. This guide will show you how to remove the display from the front of your device.
부품
지정된 부품이 없습니다.
  1. Open the lid by turning it counter-clockwise and lifting up. Remove the inner pot. Remove the inner pot.
    • Open the lid by turning it counter-clockwise and lifting up.
    • Remove the inner pot.
  2. Turn the Instant Pot upside down. Remove the single 12-mm screw by using the T-15 head screwdriver and turning it counter-clockwise. Turn the plate counter-clockwise and lift it off the Instant Pot.
    • Turn the Instant Pot upside down.
    • Remove the single 12-mm screw by using the T-15 head screwdriver and turning it counter-clockwise.
    • Turn the plate counter-clockwise and lift it off the Instant Pot.
  3. Remove the three 19-mm screws in the  black plastic base's edge using the PH-1 head screwdriver and twisting counter-clockwise. Remove the three 19-mm screws in the  black plastic base's edge using the PH-1 head screwdriver and twisting counter-clockwise.
    • Remove the three 19-mm screws in the black plastic base's edge using the PH-1 head screwdriver and twisting counter-clockwise.
  4. 아이폰 배터리 수리 키트
    Only $29.99
    Buy Now
    아이폰 배터리 수리 키트
    Only $29.99
    Buy Now
  5. Pull the power cord out of its slot. Pull up on the edge of the black plastic base to remove the base.
    • Pull the power cord out of its slot.
    • Pull up on the edge of the black plastic base to remove the base.
  6. Disconnect the two green-striped yellow wires that are connected onto the bottom of the heating element.  Use a PH-1 head screwdriver and turn counter-clockwise to remove the 10-mm screw holding them in place. Be careful not to lose the small washer that comes with this screw. Pull up on the cn101 connection to detach the LED display from the motherboard.
    • Disconnect the two green-striped yellow wires that are connected onto the bottom of the heating element. Use a PH-1 head screwdriver and turn counter-clockwise to remove the 10-mm screw holding them in place.
    • Be careful not to lose the small washer that comes with this screw.
    • Pull up on the cn101 connection to detach the LED display from the motherboard.
  7. Lift the silver outer shell off of the top black ring.
    • Lift the silver outer shell off of the top black ring.
  8. Remove the two 10-mm screws connecting the LED display to the outer shell using a PH-1 head screwdriver and twisting counter clockwise. Pull out the  LED display by pulling on it gently. Pull out the  LED display by pulling on it gently.
    • Remove the two 10-mm screws connecting the LED display to the outer shell using a PH-1 head screwdriver and twisting counter clockwise.
    • Pull out the LED display by pulling on it gently.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Kayla Meacham
회원 가입일: 2018년 01월 23일
570 평판
안내서 5개 작성하였습니다
Cal Poly, Team S18-G2, Livingston Winter 2018 Cal Poly, Team S18-G2, Livingston Winter 2018 회원
CPSU-LIVINGSTON-W18S18G2
4 회원들
안내서 5개 작성하였습니다
Where can I get the replacement for the display?
Starfish Doodle - 답글
댓글 쓰기
조회 통계:
지난 24시간: 9
지난 7일: 27
지난 30일: 77
전체 시간: 2,116
