주요 콘텐츠로 건너뛰기
Instant Pot IP-DUO80 V2 LED Display Replacement
필요한 것
  1. Instant Pot IP-DUO80 V2 LED Display Replacement, LED Display: 1 단계, 이미지 3개 중 1개 Instant Pot IP-DUO80 V2 LED Display Replacement, LED Display: 1 단계, 이미지 3개 중 2개 Instant Pot IP-DUO80 V2 LED Display Replacement, LED Display: 1 단계, 이미지 3개 중 3개
    • Open the lid by turning it counter-clockwise and lifting up.
    • Remove the inner pot.
  2. Instant Pot IP-DUO80 V2 LED Display Replacement: 2 단계, 이미지 3개 중 1개 Instant Pot IP-DUO80 V2 LED Display Replacement: 2 단계, 이미지 3개 중 2개 Instant Pot IP-DUO80 V2 LED Display Replacement: 2 단계, 이미지 3개 중 3개
    • Turn the Instant Pot upside down.
    • Remove the single 12-mm screw by using the T-15 head screwdriver and turning it counter-clockwise.
    • Turn the plate counter-clockwise and lift it off the Instant Pot.
  3. Instant Pot IP-DUO80 V2 LED Display Replacement: 3 단계, 이미지 2개 중 1개 Instant Pot IP-DUO80 V2 LED Display Replacement: 3 단계, 이미지 2개 중 2개
    • Remove the three 19-mm screws in the black plastic base's edge using the PH-1 head screwdriver and twisting counter-clockwise.
  4. Instant Pot IP-DUO80 V2 LED Display Replacement: 4 단계, 이미지 2개 중 1개 Instant Pot IP-DUO80 V2 LED Display Replacement: 4 단계, 이미지 2개 중 2개
    • Pull the power cord out of its slot.
    • Pull up on the edge of the black plastic base to remove the base.
  5. Instant Pot IP-DUO80 V2 LED Display Replacement: 5 단계, 이미지 3개 중 1개 Instant Pot IP-DUO80 V2 LED Display Replacement: 5 단계, 이미지 3개 중 2개 Instant Pot IP-DUO80 V2 LED Display Replacement: 5 단계, 이미지 3개 중 3개
    • Disconnect the two green-striped yellow wires that are connected onto the bottom of the heating element. Use a PH-1 head screwdriver and turn counter-clockwise to remove the 10-mm screw holding them in place.
    • Be careful not to lose the small washer that comes with this screw.
    • Pull up on the cn101 connection to detach the LED display from the motherboard.
  6. Instant Pot IP-DUO80 V2 LED Display Replacement: 6 단계, 이미지 1개 중 1개
    • Lift the silver outer shell off of the top black ring.
  7. Instant Pot IP-DUO80 V2 LED Display Replacement: 7 단계, 이미지 3개 중 1개 Instant Pot IP-DUO80 V2 LED Display Replacement: 7 단계, 이미지 3개 중 2개 Instant Pot IP-DUO80 V2 LED Display Replacement: 7 단계, 이미지 3개 중 3개
    • Remove the two 10-mm screws connecting the LED display to the outer shell using a PH-1 head screwdriver and twisting counter clockwise.
    • Pull out the LED display by pulling on it gently.
결론
다른 7명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Kayla Meacham
회원 가입일: 01/23/18
646 평판
안내서 5개를 작성함
Cal Poly, Team S18-G2, Livingston Winter 2018 Cal Poly, Team S18-G2, Livingston Winter 2018 회원
CPSU-LIVINGSTON-W18S18G2
4 회원들
안내서 13개를 작성함
2가이드 댓글
Where can I get the replacement for the display?
Starfish Doodle - 답글
Hola disculpa, donde puedo conseguir la pantalla led de mi instat pot DUO PLUS MULTI-COOKER 9in 1
Evaristo - 답글
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 10
지난 30일: 68
전체 시간: 7,844
