주요 콘텐츠로 건너뛰기
Instant Pot IP-DUO80 V2 Sealing Ring Replacement
필요한 것
  1. Instant Pot IP-DUO80 V2 Sealing Ring Replacement, Sealing Ring: 1 단계, 이미지 1/2 Instant Pot IP-DUO80 V2 Sealing Ring Replacement, Sealing Ring: 1 단계, 이미지 2/2
    • Remove the lid of the Instant Pot by twisting it counter-clockwise.
    • Flip the lid upside down.
  2. Instant Pot IP-DUO80 V2 Sealing Ring Replacement: 2 단계, 이미지 1/3 Instant Pot IP-DUO80 V2 Sealing Ring Replacement: 2 단계, 이미지 2/3 Instant Pot IP-DUO80 V2 Sealing Ring Replacement: 2 단계, 이미지 3/3
    • Push the bottom of the sealing ring in and up to detach one section of it from the metal ring.
    • Put your finger between the loosened sealing ring and the metal ring and slide your finger around the circumference of the lid to fully release the ring.
    • During reassembly, push one section of sealing ring down and around the metal ring (concave side of sealing ring facing metal ring) and continue with same motion around the whole ring.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Kayla Meacham
회원 가입일: 01/23/18
634 평판
안내서 5개 작성하였습니다
Cal Poly, Team S18-G2, Livingston Winter 2018 Cal Poly, Team S18-G2, Livingston Winter 2018 회원
CPSU-LIVINGSTON-W18S18G2
4 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 8
30일 전: 30
전체 시간: 1,624
