주요 콘텐츠로 건너뛰기
Instant Pot Smart-60 Disassembly
필요한 것
  1. Instant Pot Smart-60 Disassembly, Bottom access plate screw: 1 단계, 이미지 1/3 Instant Pot Smart-60 Disassembly, Bottom access plate screw: 1 단계, 이미지 2/3 Instant Pot Smart-60 Disassembly, Bottom access plate screw: 1 단계, 이미지 3/3
    • Insert wisdom here.
  2. Instant Pot Smart-60 Disassembly, Bottom bracket - remove battery holder, then 3x bolts: 2 단계, 이미지 1/3 Instant Pot Smart-60 Disassembly, Bottom bracket - remove battery holder, then 3x bolts: 2 단계, 이미지 2/3 Instant Pot Smart-60 Disassembly, Bottom bracket - remove battery holder, then 3x bolts: 2 단계, 이미지 3/3
    • Remove 3x bolts
  3. Instant Pot Smart-60 Disassembly, Bottom bracket - snap out power receptacle: 3 단계, 이미지 1/3 Instant Pot Smart-60 Disassembly, Bottom bracket - snap out power receptacle: 3 단계, 이미지 2/3 Instant Pot Smart-60 Disassembly, Bottom bracket - snap out power receptacle: 3 단계, 이미지 3/3
  4. Instant Pot Smart-60 Disassembly, Circuit board 1: 4 단계, 이미지 1/3 Instant Pot Smart-60 Disassembly, Circuit board 1: 4 단계, 이미지 2/3 Instant Pot Smart-60 Disassembly, Circuit board 1: 4 단계, 이미지 3/3
    • Black molex connector on top right must come out to remove the outer shell.
    • Red wire spring clips with blue translucent covers I was unable to remove safely, I suggest removing other ends of those wires if you need to remove the heating element plate.
  5. Instant Pot Smart-60 Disassembly, Battery and front panel wires: 5 단계, 이미지 1/3 Instant Pot Smart-60 Disassembly, Battery and front panel wires: 5 단계, 이미지 2/3 Instant Pot Smart-60 Disassembly, Battery and front panel wires: 5 단계, 이미지 3/3
    • I needed small needle nose pliers to pinch and remove wide front panel connector.
  6. Instant Pot Smart-60 Disassembly, Outer shell ground wire: 6 단계, 이미지 1/3 Instant Pot Smart-60 Disassembly, Outer shell ground wire: 6 단계, 이미지 2/3 Instant Pot Smart-60 Disassembly, Outer shell ground wire: 6 단계, 이미지 3/3
  7. Instant Pot Smart-60 Disassembly, Outer shell removal - release tape from lid sensor wire: 7 단계, 이미지 1/3 Instant Pot Smart-60 Disassembly, Outer shell removal - release tape from lid sensor wire: 7 단계, 이미지 2/3 Instant Pot Smart-60 Disassembly, Outer shell removal - release tape from lid sensor wire: 7 단계, 이미지 3/3
  8. Instant Pot Smart-60 Disassembly, Outer shell re-assembly - lid sensor wire notch: 8 단계, 이미지 1/3 Instant Pot Smart-60 Disassembly, Outer shell re-assembly - lid sensor wire notch: 8 단계, 이미지 2/3 Instant Pot Smart-60 Disassembly, Outer shell re-assembly - lid sensor wire notch: 8 단계, 이미지 3/3
    • I'm skipping removing heating element and nearby sensors, it's similar to other models. Search for Instant Pot repair videos for instructions.
  9. Instant Pot Smart-60 Disassembly, Outer shell re-assembly - lid sensor wire goes into notch: 9 단계, 이미지 1/3 Instant Pot Smart-60 Disassembly, Outer shell re-assembly - lid sensor wire goes into notch: 9 단계, 이미지 2/3 Instant Pot Smart-60 Disassembly, Outer shell re-assembly - lid sensor wire goes into notch: 9 단계, 이미지 3/3
  10. Instant Pot Smart-60 Disassembly, Outer shell re-assembly: 10 단계, 이미지 1/2 Instant Pot Smart-60 Disassembly, Outer shell re-assembly: 10 단계, 이미지 2/2
    • Pull lid sensor wire up, re-tape to inside of outer shell.
    • Battery replacement, you should remove the screw and pull the mini circuit board holding the battery before attempting to swap batteries.
결론
다른 5명이 해당 안내서를 완성하였습니다.
Zen1
회원 가입일: 03/01/18
311 평판
안내서 1개 작성함
댓글 2개
If the outer shell is dented but panel is functioning is it safe to operate the instant pot? looks like it moved a bit in the box in shipment, no visible damage to the pot just the to the aluminum shell
Jeff Medlin - 답글
Mine is dented and it should be totally fine. As you said, the pressure vessel is separate from the outer shell, so there are no safety concerns. Just asthetic. I wish there wasn't this gap of air between the pressure vessel and the outer shell, or, I wish the shell was a bit more durable as it's VERY easily dented.
Kuake Ye - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 17
30일 전: 105
전체 시간: 7,679
