주요 콘텐츠로 건너뛰기
Instant Pot Smart-60 Plastic Base Replacement
필요한 것
  1. Instant Pot Smart-60 Plastic Base Replacement, Plastic Base: 1 단계, 이미지 1/2 Instant Pot Smart-60 Plastic Base Replacement, Plastic Base: 1 단계, 이미지 2/2
    • Take off the lid of the Instant Pot. Grasp the handle and rotate the lid counter-clockwise, then lift up to separate the lid from the base.
  2. Instant Pot Smart-60 Plastic Base Replacement: 2 단계, 이미지 1/1
    • Take out the inner pot and place it somewhere out of the way.
  3. Instant Pot Smart-60 Plastic Base Replacement: 3 단계, 이미지 1/1
    • Flip the Instant Pot over on its top so that the base is facing upward.
  4. Instant Pot Smart-60 Plastic Base Replacement: 4 단계, 이미지 1/1
    • Remove the single 12mm Phillips #2 screw holding the base to the device.
  5. Instant Pot Smart-60 Plastic Base Replacement: 5 단계, 이미지 1/1
    • Rotate the base counter-clockwise, then gently lift the base off of the device.
결론
다른 3명이 해당 안내서를 완성하였습니다.
paola alvarez
회원 가입일: 01/24/18
534 평판
안내서 4개 작성하였습니다
Cal Poly, Team S1-G4, Livingston Winter 2018 Cal Poly, Team S1-G4, Livingston Winter 2018 회원
CPSU-LIVINGSTON-W18S1G4
4 회원들
안내서 6개 작성하였습니다
댓글 13개
Hi, I would like to know, where can I buy a new plastic base? Thank you
nathaliawed - 답글
Hello where can I buy the plastic base
Maureen - 답글
I would like to buy one of these for an 8 Qt model….very hard to source this and terrible customer support as this seems to be a issue for many that burned theirs.
davidghamilton - 답글
Did you ever find out where you can buy this part.
Thank you. Belinda
Belinda Berka - 답글
Do you carry the replacement for this. Thanks
khai01 - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 6
30일 전: 35
전체 시간: 6,694
