주요 콘텐츠로 건너뛰기
Instax Mini 90 Film Cartridge Replacement
필요한 것
  1. Instax Mini 90  Film Cartridge Replacement, Film Cartridge: 1 단계, 이미지 1개 중 1개
    • Turn ON the camera, and flip it over so that the back cover is visible.
  2. Instax Mini 90  Film Cartridge Replacement: 2 단계, 이미지 3개 중 1개 Instax Mini 90  Film Cartridge Replacement: 2 단계, 이미지 3개 중 2개 Instax Mini 90  Film Cartridge Replacement: 2 단계, 이미지 3개 중 3개
    • Unlock the back cover. It should automatically spring open. If there is an old film cartridge loaded in the camera, remove it.
  3. Instax Mini 90  Film Cartridge Replacement: 3 단계, 이미지 3개 중 1개 Instax Mini 90  Film Cartridge Replacement: 3 단계, 이미지 3개 중 2개 Instax Mini 90  Film Cartridge Replacement: 3 단계, 이미지 3개 중 3개
    • Unwrap the new film cartridge, taking care to not touch the film inside. Only handle the film cartridge by its plastic shell.
    • Line up the small, yellow line on the cartridge with the corresponding yellow line inside the camera. The yellow line on the cartridge should be facing up, away from the camera.
  4. Instax Mini 90  Film Cartridge Replacement: 4 단계, 이미지 2개 중 1개 Instax Mini 90  Film Cartridge Replacement: 4 단계, 이미지 2개 중 2개
    • Close the back cover. The film covering should eject automatically.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Elliott Tegan-Tawney
회원 가입일: 02/28/17
690 평판
안내서 5개를 작성함
USF Tampa, Team S2-G1, Nance Spring 2017 USF Tampa, Team S2-G1, Nance Spring 2017 회원
USFT-NANCE-S17S2G1
4 회원들
안내서 12개를 작성함
5가이드 댓글
Having an issue with the film pack not loading. Have tried resetting, removing battery etc. Any ideas?
Lawrence Cassel - 답글
Me too! Ive removed battery, replaced with fresh battery, nothing happens! Ive just used it once! Help!!
susan ahrent - 답글
I’m having the same problem and I’ve tried everything. Someone help! The film simply isn’t being recognized (no blinking E or anything like that).
ap5029 - 답글
I am not too sure how to fix that, but definitely try contacting Fujifilm, as they know much more about their products and do repairs as well! https://www.fujifilmusa.com/support/Serv...
Elliott Tegan-Tawney - 답글
I have a fujifilm instax mini evo hybrid black instant camera but it does not detect film. The message of putting a new cartridge keeps popping-up. Do you know what could be the cause?
Herman Saldana - 답글
댓글 쓰기
조회 통계:
지난 24시간: 4
지난 7일: 20
지난 30일: 106
전체 시간: 23,475
