주요 콘텐츠로 건너뛰기
Instax Mini 90 Battery Replacement
필요한 것
  1. Instax Mini 90 Battery Replacement, Battery: 1 단계, 이미지 2개 중 1개 Instax Mini 90 Battery Replacement, Battery: 1 단계, 이미지 2개 중 2개
    • The battery compartment can be found on the backside of the camera. Pinpoint this compartment and focus on the right edge of the compartment gate to find the opening latch.
  2. Instax Mini 90 Battery Replacement: 2 단계, 이미지 2개 중 1개 Instax Mini 90 Battery Replacement: 2 단계, 이미지 2개 중 2개
    • Pinch the latch in towards the battery compartment gate. This will release the gate and allow it to open.
    • Completely open the gate and remove from camera for ease of insertion of the battery.
  3. Instax Mini 90 Battery Replacement: 3 단계, 이미지 2개 중 1개 Instax Mini 90 Battery Replacement: 3 단계, 이미지 2개 중 2개
    • Insert the battery into the battery compartment by following the diagram printed on the camera.
    • Be sure to connect the correct terminals of the battery to the camera.
    • Reattach battery compartment door to the camera and close firmly. A clicking sound will result when compartment door has been closed fully.
결론
다른 2명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Elliott Tegan-Tawney
회원 가입일: 02/28/17
690 평판
안내서 5개를 작성함
USF Tampa, Team S2-G1, Nance Spring 2017 USF Tampa, Team S2-G1, Nance Spring 2017 회원
USFT-NANCE-S17S2G1
4 회원들
안내서 12개를 작성함
1가이드 댓글
Also use a #0 screwdriver, not a 000#. The 000 may work but the 0 fits better
John Doe - 답글
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 15
지난 30일: 68
전체 시간: 13,781
