주요 콘텐츠로 건너뛰기
Intel NUC5i7RYH Disassembly
필요한 것
  1. Intel NUC5i7RYH Disassembly, Lower Lid: 1 단계, 이미지 2개 중 1개 Intel NUC5i7RYH Disassembly, Lower Lid: 1 단계, 이미지 2개 중 2개
    • Place the NUC upside down and start by using a Phillips head screw driver to remove the lower screws on the lower case door.
    • These screws are held in with retainers, so they won't fall out when you flip the lid.
  2. Intel NUC5i7RYH Disassembly, Lid and HDD Bracket: 2 단계, 이미지 3개 중 1개 Intel NUC5i7RYH Disassembly, Lid and HDD Bracket: 2 단계, 이미지 3개 중 2개 Intel NUC5i7RYH Disassembly, Lid and HDD Bracket: 2 단계, 이미지 3개 중 3개
    • Lift the door, and keep an eye on the cables that connect to the NUC's motherboard. These cables are the power and data cables for the 2.5" hard drive bay.
    • Carefully unplug the cables from the motherboard, and set the bracket aside.
    • In the last photo, the slot for a blade SSD is marked. This is where you would install the blade SSD, and use a screw to hold it in place.
  3. Intel NUC5i7RYH Disassembly, HDD Bracket Disassembly: 3 단계, 이미지 3개 중 1개 Intel NUC5i7RYH Disassembly, HDD Bracket Disassembly: 3 단계, 이미지 3개 중 2개 Intel NUC5i7RYH Disassembly, HDD Bracket Disassembly: 3 단계, 이미지 3개 중 3개
    • Remove the 4 silver screws that hold the hard drive in the bracket. The metal shield with thermal pad in the red box will come off: this comes in handy if you have a blade SSD installed, as it insulates it from the metal.
    • Carefully slide the 2.5" HDD or SSD out of its case.
  4. Intel NUC5i7RYH Disassembly, RAM Removal: 4 단계, 이미지 3개 중 1개 Intel NUC5i7RYH Disassembly, RAM Removal: 4 단계, 이미지 3개 중 2개 Intel NUC5i7RYH Disassembly, RAM Removal: 4 단계, 이미지 3개 중 3개
    • Removal of RAM on these units is just like on a standard laptop: slightly bend each arm on each side of the chip, and allow it to pop up before sliding it out of the socket.
    • If using two sticks of RAM, repeat this process for the lower stick underneath.
  5. Intel NUC5i7RYH Disassembly, Motherboard Removal: 5 단계, 이미지 3개 중 1개 Intel NUC5i7RYH Disassembly, Motherboard Removal: 5 단계, 이미지 3개 중 2개 Intel NUC5i7RYH Disassembly, Motherboard Removal: 5 단계, 이미지 3개 중 3개
    • The motherboard is held in with two black Phillips head screws, located on the left hand side.
    • Be sure to unplug the antenna cables from the wireless card before removing the motherboard.
    • Grasp the ethernet port, and lift the board out of the case.
  6. Intel NUC5i7RYH Disassembly, Motherboard Removal, continued.: 6 단계, 이미지 3개 중 1개 Intel NUC5i7RYH Disassembly, Motherboard Removal, continued.: 6 단계, 이미지 3개 중 2개 Intel NUC5i7RYH Disassembly, Motherboard Removal, continued.: 6 단계, 이미지 3개 중 3개
    • The motherboard should lift right out of the case.
    • To remove the fan, unscrew the two Phillips head screws holding it in. It can then be unplugged from the motherboard.
  7. Intel NUC5i7RYH Disassembly, Finish!: 7 단계, 이미지 1개 중 1개
    • This unit is relatively easy to disassemble and reassemble. Good luck!
결론
다른 20명이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Jasen Friedle
회원 가입일: 08/25/14
3,872 평판
안내서 3개를 작성함
15가이드 댓글
Clear description, I used it for NUC7i7RYH, where my cpu was often 100 degrees.
I followed your instruction and cleaned the ventilator and removed dust in the ventilation channels.
Problem fixed, temp is now between 50 and 70 degrees.
rob - 답글
Congrats! Thanks for letting me know, and I’m glad to hear your machine is running cooler!
Jasen Friedle - 답글
Hello, I need an audio jack (port) fro this nuc, can’t find it anywhere, any suggestions?
model 5i5ryh
dave - 답글
hello. I need a replacement audio jack (port) for this nuc, model 5i5ryh, can’t find it anywhere, any suggestions?
dave - 답글
You can try looking on eBay for replacement audio jacks. From what I’m seeing, you could potentially use a universal one and solder a few jumper wires to their corresponding pins and make something work.
Jasen Friedle -
댓글 쓰기
조회 통계:
지난 24시간: 19
지난 7일: 126
지난 30일: 551
전체 시간: 61,090
