주요 콘텐츠로 건너뛰기
Inter-tel IP 8660 Button Pad Replacement
필요한 것
  1. Inter-tel IP 8660 Button Pad Replacement, Rear Cover: 1 단계, 이미지 1/1
    • Before disassembling the phone, make sure it is not plugged into power and the handset phone cord is disconnected from the handset jack.
  2. Inter-tel IP 8660 Button Pad Replacement: 2 단계, 이미지 1/3 Inter-tel IP 8660 Button Pad Replacement: 2 단계, 이미지 2/3 Inter-tel IP 8660 Button Pad Replacement: 2 단계, 이미지 3/3
    • Unscrew the 9 highlighted screws using a #1 Phillips head screwdriver. You can use a magnetized screwdriver to draw them out.
    • 8 mm long
    • 11 mm long
  3. Inter-tel IP 8660 Button Pad Replacement: 3 단계, 이미지 1/1
    • Lift up the back cover and set it aside.
  4. Inter-tel IP 8660 Button Pad Replacement, Internal speaker: 4 단계, 이미지 1/1
    • While holding down the motherboard, gently pull the wire harness connecting the speaker to the motherboard until it comes free.
  5. Inter-tel IP 8660 Button Pad Replacement: 5 단계, 이미지 1/1
    • Lift up the speaker.
  6. Inter-tel IP 8660 Button Pad Replacement, Button Pad: 6 단계, 이미지 1/1
    • Lift up the motherboard and set aside
  7. Inter-tel IP 8660 Button Pad Replacement: 7 단계, 이미지 1/1
    • Peel off all rubber button covers.
  8. Inter-tel IP 8660 Button Pad Replacement: 8 단계, 이미지 1/1
    • Remove all plastic buttons. (Note: Look at the initial picture for locations of each button set)
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Juan David GutierrezFranco
회원 가입일: 01/20/12
67 평판
안내서 4개 작성하였습니다
Cal Poly, Team 11-24, Maness Winter 2012 Cal Poly, Team 11-24, Maness Winter 2012 회원
CPSU-MANESS-W12S11G24
4 회원들
안내서 14개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 2
전체 시간: 762
