주요 콘텐츠로 건너뛰기
소개
This guide details the steps to take off the back cover of your Inter-tel IP 8660 handset.
부품
지정된 부품이 없습니다.
  1. Disconnect the phone cord from the handset jack.
    • Disconnect the phone cord from the handset jack.
  2. Unscrew the two black screws (8 mm long) located in the middle of the handset using #1 Phillips head. Unscrew the two black screws (8 mm long) located in the middle of the handset using #1 Phillips head.
    • Unscrew the two black screws (8 mm long) located in the middle of the handset using #1 Phillips head.
  3. Pry the back cover off the headset using a spudger. It is best to pry at the top of the handset. Pry the back cover off the headset using a spudger. It is best to pry at the top of the handset.
    • Pry the back cover off the headset using a spudger. It is best to pry at the top of the handset.
결론
Juan David GutierrezFranco
회원 가입일: 2012년 01월 20일
67 평판
안내서 4개 작성하였습니다
Cal Poly, Team 11-24, Maness Winter 2012 Cal Poly, Team 11-24, Maness Winter 2012 회원
CPSU-MANESS-W12S11G24
4 회원들
안내서 7개 작성하였습니다
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 1
전체 시간: 567
