주요 콘텐츠로 건너뛰기
Inter-tel IP 8660 Handset Microphone and Receiver. Replacement
필요한 것
  1. Inter-tel IP 8660 Handset Microphone and Receiver. Replacement, Handset Back Cover: 1 단계, 이미지 1/1
    • Disconnect the phone cord from the handset jack.
  2. Inter-tel IP 8660 Handset Microphone and Receiver. Replacement: 2 단계, 이미지 1/2 Inter-tel IP 8660 Handset Microphone and Receiver. Replacement: 2 단계, 이미지 2/2
    • Unscrew the two black screws (8 mm long) located in the middle of the handset using #1 Phillips head.
  3. Inter-tel IP 8660 Handset Microphone and Receiver. Replacement: 3 단계, 이미지 1/2 Inter-tel IP 8660 Handset Microphone and Receiver. Replacement: 3 단계, 이미지 2/2
    • Pry the back cover off the headset using a spudger. It is best to pry at the top of the handset.
  4. Inter-tel IP 8660 Handset Microphone and Receiver. Replacement, Handset Microphone and Receiver.: 4 단계, 이미지 1/1
    • While holding the handset front cover, grasp and twist the handset microphone and jack until they come free from the cover.
  5. Inter-tel IP 8660 Handset Microphone and Receiver. Replacement: 5 단계, 이미지 1/3 Inter-tel IP 8660 Handset Microphone and Receiver. Replacement: 5 단계, 이미지 2/3 Inter-tel IP 8660 Handset Microphone and Receiver. Replacement: 5 단계, 이미지 3/3
    • Unscrew the 2 screws (8 mm long) that hold the receiver in place using a #1 Phillips screwdriver.
    • Note: The screws come with washers.
  6. Inter-tel IP 8660 Handset Microphone and Receiver. Replacement: 6 단계, 이미지 1/2 Inter-tel IP 8660 Handset Microphone and Receiver. Replacement: 6 단계, 이미지 2/2
    • Pull the red and green wires that connect the receiver to the microphone out from under the metal piece and black padding.
    • Note: To insert the wires back underneath the black padding, pull the black padding back with your finger and use plastic opening tool to wedge the wires underneath the black padding.
결론
Juan David GutierrezFranco
회원 가입일: 01/20/12
67 평판
안내서 4개 작성하였습니다
Cal Poly, Team 11-24, Maness Winter 2012 Cal Poly, Team 11-24, Maness Winter 2012 회원
CPSU-MANESS-W12S11G24
4 회원들
안내서 14개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 1
전체 시간: 965
