주요 콘텐츠로 건너뛰기
Inter-tel IP 8660 LCD Screen Replacement
필요한 것
  1. Inter-tel IP 8660 LCD Screen Replacement, Rear Cover: 1 단계, 이미지 1/1
    • Before disassembling the phone, make sure it is not plugged into power and the handset phone cord is disconnected from the handset jack.
  2. Inter-tel IP 8660 LCD Screen Replacement: 2 단계, 이미지 1/3 Inter-tel IP 8660 LCD Screen Replacement: 2 단계, 이미지 2/3 Inter-tel IP 8660 LCD Screen Replacement: 2 단계, 이미지 3/3
    • Unscrew the 9 highlighted screws using a #1 Phillips head screwdriver. You can use a magnetized screwdriver to draw them out.
    • 8 mm long
    • 11 mm long
  3. Inter-tel IP 8660 LCD Screen Replacement: 3 단계, 이미지 1/1
    • Lift up the back cover and set it aside.
  4. Inter-tel IP 8660 LCD Screen Replacement, Internal speaker: 4 단계, 이미지 1/1
    • While holding down the motherboard, gently pull the wire harness connecting the speaker to the motherboard until it comes free.
  5. Inter-tel IP 8660 LCD Screen Replacement: 5 단계, 이미지 1/1
    • Lift up the speaker.
  6. Inter-tel IP 8660 LCD Screen Replacement, LCD Screen: 6 단계, 이미지 1/3 Inter-tel IP 8660 LCD Screen Replacement, LCD Screen: 6 단계, 이미지 2/3 Inter-tel IP 8660 LCD Screen Replacement, LCD Screen: 6 단계, 이미지 3/3
    • Lift up the motherboard out of its housing in the front cover of the phone.
    • Set the front cover and button pads aside.
  7. Inter-tel IP 8660 LCD Screen Replacement: 7 단계, 이미지 1/3 Inter-tel IP 8660 LCD Screen Replacement: 7 단계, 이미지 2/3 Inter-tel IP 8660 LCD Screen Replacement: 7 단계, 이미지 3/3
    • Using tweezers, pinch the highlighted connective clips together and depress. Start with the clips in the middle of the motherboard first.
    • Note: There are four clips, one at each corner of the LCD screen.
  8. Inter-tel IP 8660 LCD Screen Replacement: 8 단계, 이미지 1/1
    • Flip the motherboard over so that the LCD screen is facing upward.
  9. Inter-tel IP 8660 LCD Screen Replacement: 9 단계, 이미지 1/2 Inter-tel IP 8660 LCD Screen Replacement: 9 단계, 이미지 2/2
    • Push the black clip holding the ribbon cable out of its casing using the plastic opening tool.
    • This is done using the spudger to lift one side out of its housing.
    • Reposition the spudger to the other side of the black clip and push it flush with the other end.
    • Note: The black clip pushes out of the housing and does not come completely loose.
  10. Inter-tel IP 8660 LCD Screen Replacement: 10 단계, 이미지 1/3 Inter-tel IP 8660 LCD Screen Replacement: 10 단계, 이미지 2/3 Inter-tel IP 8660 LCD Screen Replacement: 10 단계, 이미지 3/3
    • Pull gently on the ribbon cable so that it comes loose from the black clip.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Juan David GutierrezFranco
회원 가입일: 01/20/12
67 평판
안내서 4개 작성하였습니다
Cal Poly, Team 11-24, Maness Winter 2012 Cal Poly, Team 11-24, Maness Winter 2012 회원
CPSU-MANESS-W12S11G24
4 회원들
안내서 14개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 3
전체 시간: 836
