소개
The Intex Quick-Fill air pump motor can burn out through normal use over time. The pump fans can also break if a foreign object makes it's way into the pump. If your Intex air pump (Quick-Fill AP636) has ceased to properly function and needs a motor replacement follow this guide to do so. Please make sure air pump is not plugged in before starting replacement.
필요한 것
Remove the air pump attachment by turning it counter clockwise to the unlocked position.
