주요 콘텐츠로 건너뛰기
Iomega Z100S2 Case Replacement
필요한 것
  1. Iomega Z100S2 Case Replacement, Case: 1 단계, 이미지 1/2 Iomega Z100S2 Case Replacement, Case: 1 단계, 이미지 2/2
    • Push in the plastic tab that can be seen through cracks in the front left corner using a spudger.
  2. Iomega Z100S2 Case Replacement: 2 단계, 이미지 1/1
    • Move down the same side and push in the plastic tab.
  3. Iomega Z100S2 Case Replacement: 3 단계, 이미지 1/1
    • Move to the front right side and once again push in the plastic tab.
    • There is not a fourth tab to push in after this one.
  4. Iomega Z100S2 Case Replacement: 4 단계, 이미지 1/2 Iomega Z100S2 Case Replacement: 4 단계, 이미지 2/2
    • Grab the cover by the front side and pull upwards.
    • You might encounter some resistance. Pull firmly, but don't yank it.
  5. Iomega Z100S2 Case Replacement: 5 단계, 이미지 1/2 Iomega Z100S2 Case Replacement: 5 단계, 이미지 2/2
    • Tilt the front case down until the pegs detach from the bottom of the case.
    • Lift up and outward.
    • The motherboard will be loose at this point.
결론
다른 5명이 해당 안내서를 완성하였습니다.
Chris Rudolph
회원 가입일: 10/05/10
82 평판
안내서 1개 작성함
Cal Poly, Team 7-53, Amido Fall 2010 Cal Poly, Team 7-53, Amido Fall 2010 회원
CPSU-AMIDO-F10S7G53
4 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 26
전체 시간: 4,149
