주요 콘텐츠로 건너뛰기
Iomega Z100S2 Motherboard Replacement
필요한 것
  1. Iomega Z100S2 Motherboard Replacement, Case: 1 단계, 이미지 1/2 Iomega Z100S2 Motherboard Replacement, Case: 1 단계, 이미지 2/2
    • Push in the plastic tab that can be seen through cracks in the front left corner using a spudger.
  2. Iomega Z100S2 Motherboard Replacement: 2 단계, 이미지 1/1
    • Move down the same side and push in the plastic tab.
  3. Iomega Z100S2 Motherboard Replacement: 3 단계, 이미지 1/1
    • Move to the front right side and once again push in the plastic tab.
    • There is not a fourth tab to push in after this one.
  4. Iomega Z100S2 Motherboard Replacement: 4 단계, 이미지 1/2 Iomega Z100S2 Motherboard Replacement: 4 단계, 이미지 2/2
    • Grab the cover by the front side and pull upwards.
    • You might encounter some resistance. Pull firmly, but don't yank it.
  5. Iomega Z100S2 Motherboard Replacement: 5 단계, 이미지 1/2 Iomega Z100S2 Motherboard Replacement: 5 단계, 이미지 2/2
    • Tilt the front case down until the pegs detach from the bottom of the case.
    • Lift up and outward.
    • The motherboard will be loose at this point.
  6. Iomega Z100S2 Motherboard Replacement, Disk Reader: 6 단계, 이미지 1/2 Iomega Z100S2 Motherboard Replacement, Disk Reader: 6 단계, 이미지 2/2
    • Unhook the two springs from the front plastic hooks.
    • The black side rails of the reader should easily slide forward and off.
  7. Iomega Z100S2 Motherboard Replacement: 7 단계, 이미지 1/1
    • There is a white tab connected to the motherboard. Pull it upward by gently rocking it back and forth.
    • The tab does not come completely out, it only slides up slightly, so don't rip it out!
  8. Iomega Z100S2 Motherboard Replacement: 8 단계, 이미지 1/2 Iomega Z100S2 Motherboard Replacement: 8 단계, 이미지 2/2
    • Grab the reader by its sides and gently pull it upward.
    • There are two wires still connected to the bottom of the reader that haven't been detached.
  9. Iomega Z100S2 Motherboard Replacement: 9 단계, 이미지 1/1
    이 단계에 사용된 도구:
    구매
    • Disconnect the white wires by using tweezers to gently pull the bottom connector toward you.
  10. Iomega Z100S2 Motherboard Replacement: 10 단계, 이미지 1/2 Iomega Z100S2 Motherboard Replacement: 10 단계, 이미지 2/2
    • Disconnect the thin ribbon wire by using tweezers to gently pull the connector at the bottom toward you.
  11. Iomega Z100S2 Motherboard Replacement: 11 단계, 이미지 1/1
    • Lift the reader up and out from the device.
  12. Iomega Z100S2 Motherboard Replacement, Motherboard: 12 단계, 이미지 1/2 Iomega Z100S2 Motherboard Replacement, Motherboard: 12 단계, 이미지 2/2
    • Use a T6 Torx Screwdriver to remove the 1.3 mm screw at the back of the motherboard.
  13. Iomega Z100S2 Motherboard Replacement: 13 단계, 이미지 1/2 Iomega Z100S2 Motherboard Replacement: 13 단계, 이미지 2/2
    • Gently lift the motherboard and back case out from the bottom case.
결론
Ezery Kennedy
회원 가입일: 10/05/10
288 평판
안내서 2개 작성하였습니다
Cal Poly, Team 7-53, Amido Fall 2010 Cal Poly, Team 7-53, Amido Fall 2010 회원
CPSU-AMIDO-F10S7G53
4 회원들
안내서 6개 작성하였습니다
댓글 한 개
how to fix the motherboard if booth leds stay lit when powering up?
ACIDGREEN TECHNO - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 23
전체 시간: 3,444
