주요 콘텐츠로 건너뛰기
Ion Air Pro Record and Stop Switch Replacement
필요한 것
  1. Ion Air Pro Record and Stop Switch Replacement, Record and Stop Switch: 1 단계, 이미지 1/1
    • Remove the six screws (3 mm) that secure the lens cover bezel with a #00 Phillips screwdriver.
  2. Ion Air Pro Record and Stop Switch Replacement: 2 단계, 이미지 1/2 Ion Air Pro Record and Stop Switch Replacement: 2 단계, 이미지 2/2
    • Remove the blue securing the lens cover. Then simply pull off the lens cover itself.
  3. Ion Air Pro Record and Stop Switch Replacement: 3 단계, 이미지 1/1
    • Remove black aluminum casing as shown.
  4. Ion Air Pro Record and Stop Switch Replacement: 4 단계, 이미지 1/1
    • Using a #00 Phillips screwdriver, unscrew the screw securing the record/stop switch.
  5. Ion Air Pro Record and Stop Switch Replacement: 5 단계, 이미지 1/1
    • Remove the record/stop switch. You are then able to replace the switch.
    • Be careful to not misplace the power button and spring that will no longer be secured when the switch is removed.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Christopher Brandl
회원 가입일: 10/09/18
673 평판
안내서 5개 작성하였습니다
UW Stout, Team S6-G2, Ogden Fall 2018 UW Stout, Team S6-G2, Ogden Fall 2018 회원
UWSTOUT-OGDEN-F18S6G2
4 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 4
전체 시간: 358
